0 members (), 177 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
#1282901 10/08/2018 7:39 AM
Are there modern replacements for these? This is for a 1947 AD 3600......
Most classic parts suppliers sell a replacement (tie rod ends) - not original style (and might need some adaptations).
Rare Parts sells an "exact" reproduction (tie rod ends: left and right).
The first part's price seem low?
RP25129
FP25128
Drag links are usually more commonly available.
Yes, look at most of the big name venders in the above links. The replacement ends are sealed and have a straight shaft the drops right in where the old studs are now. It take a some effort to get the old ones out, requires a drill, hammer, and vise, you will never get them out while still on the truck. These are direct replacement once the old ones have been removed.
Thanks, Joe
I was not sure that the "modernized" (sealed/non-adjustable) replacements were direct-fit (or, if they had tapered studs).
Moderator, Electrical Bay
Don't know about the 47, but for later models you can make a new style and adjustable drag link using parts for other trucks. Somewhere around here there was once a set of instructions.
~ Jon
I think the 1/2 ton tie rod ends have a straight shaft, the 3/4 ton ends may be tapered, allowing use of modern ends. They are tapered on later models.
Drag link
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
