7 members (TexasA&M48Truck, Nick in Manitou, UtahYork, Ponchogl, Peggy M, 2 invisible), 104 guests, and 4 robots.
Topics128,077
Posts1,056,014
Members48,433
#1281413 09/25/2018 12:23 AM
My 47 AD has had a couple of "screen door springs" wrapped around each wheel hub for as long as I have know it. I have seen several trucks like this....What exactly is the reason?
Back when I worked at Poole Chev. after school, 1965/66, I seen a lot of those and was told it was to help with the brake squeal...... if my memory is correct. Sort of a vibration damper too perhaps.
Alvin’s memory is still intact. Way to go Alvin!
Ok! Thanks!
ODSS Lawman
ODSS Lawman
Do you have a photo you can share? I’m interested to see one.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
" "screen door springs" wrapped around each wheel hub "
headscratch
anti-static device to reduce radio interference - GM truck accessory
http://chevy.oldcarmanualproject.com/radios/54craesm/54craesm39.html
figure 57, step 3
In the 1954 radio noise suppression kit, talc/talcum powder is also provided/recommended inside the cap (as I dimly recall).
No, the spring you described is around the outside of the outside of the brake drum.
dang
It took me while to "picture" what you are referring-to.
I'll go with Alvin's description.
Group 5.810 Shield-Nut-Spring Brake Drum?
Is that like putting cow magnets on the fuel line to improve gas mileage?
...on most of the drums the springs fit around a small groove close to the back of the drum which kept the springs in place.
they are one mine. I heard that they are to help with brake squeal. Seems like snake oil to me, but they didn't seem to be a problem so I left them on.
Marc S
Houston TX
1946 Chevy 1/2 Ton
