1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2018 Posts: 116 Shop Shark | | Shop Shark Joined: Feb 2018 Posts: 116 | I need the Chevy Loadmaster emblems. Does anyone have leads on where I could get a pair? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Post a want ad in the Swap Meet Forum.ðŸ›
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Post a want ad in the Swap Meet Forum.🛠Be sure to put the year in your Want Ad. | | | | | Joined: Feb 2018 Posts: 116 Shop Shark | | Shop Shark Joined: Feb 2018 Posts: 116 | Thanks for the help guys! So update on the progress. All base coats for the frame, bumper and rear wheels are complete. Pictures are linked below. There is a picture of the wheel seals and the heater. 1. Do they make those anymore or will I have to make them myself with gasket paper? Same with the rear differential? 2. Does anyone know anything about the heater? Is it really "deluxe"? https://plus.google.com/u/0/photos/...70878278511119986?authkey=COzjjf6n__eUZA | | | | | Joined: Jun 2018 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 46 |
Stuff I’m gonna work on, I swear 1963 C30 flatbed 1961 Apache 30 (parts, no title) 1960 GMC Big Bolt
Don't tweet, face, Google, or link. Just hanging in as long as I can...
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Looking good! Cool old Case tractor you have there! | | | | | Joined: Feb 2018 Posts: 116 Shop Shark | | Shop Shark Joined: Feb 2018 Posts: 116 | Thank you Rich. It's my twin brothers. He has old Case tractors and I have old Chevy trucks. We can both go bankrupt together. ha ha! | | | | | Joined: Feb 2018 Posts: 116 Shop Shark | | Shop Shark Joined: Feb 2018 Posts: 116 | So today I have been working on the front end and split the xmsn from the engine. I have a few questions. 1948 6100/6400 1. I have a mid 50s 235 that I am honing and putting new rings in. I also have the SM420 XMSN with it. If I got a SM465; would it bolt right in where the 420 was? No modifications to the engine/bell housing/truck frame? A "turn key" operation. 2. The truck had a hydrovac brake booster on it originally. Is it worth it to spend the time and money to have it rebuilt and reinstall it or just hook the brakes up the way they are now? How much of a difference does the booster make? Pictures linked below. https://plus.google.com/u/0/photos/...83827133312247138?authkey=CKmh3KLYotmIVA | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I see you have a PTO on your SM420, does the SM465 have a PTO? If not you need to confirm the one on the SM420 will work on the 465...that could be a deal breaker if you intend on using it. The Hydrovac will triple the line pressure you make with your leg...why wouldn't you want that? If you generate 500 psi, the Hydrovac adds 1000 psi more! Mike B
| | | | | Joined: Feb 2018 Posts: 116 Shop Shark | | Shop Shark Joined: Feb 2018 Posts: 116 | Im pretty sure the PTOs interchange. Am I wrong? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | What's the radio control head look like? Is the speaker in the dash? Neat old combine! Mike B  | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | sweet!! Thanks for sharing the pics! | | | | | Joined: Feb 2018 Posts: 116 Shop Shark | | Shop Shark Joined: Feb 2018 Posts: 116 | Thanks! I'm not sure where the speaker is. I will try and look tomorrow. I think in the box? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | My guess is the box is just the tube chassis and there is a remote speaker and control head. If you remove the radio cover you may find a date stamped somewhere inside the box. It looks older than the truck to me... Mike B  | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | GMC engines are about 3" longer than Chevy's, so, you will need to allow for that, GMC's move the radiator FWD in the core support.
PTO's are transmission specific, so a 420 PTO may or not fit a 465. Since you have both. Straight cut vs. 'slanted' cut gears and also depth in the gears(shims are available to depth of engagement) are some issues. I am sure there are PTO shops in IA.
Ed
| | | | | Joined: Feb 2018 Posts: 116 Shop Shark | | Shop Shark Joined: Feb 2018 Posts: 116 | Thank you Ed! Does that 3" mean that I will have to modify the firewall or just have to move the radiator forward 3"? | | | | | Joined: Feb 2018 Posts: 116 Shop Shark | | Shop Shark Joined: Feb 2018 Posts: 116 | I need help everyone. I was about to throw a wrench today. I ordered a new steering box bushing/seal kit for the horizontal shaft. I cannot get the new seal to fit over the splined shaft. Has anyone done this or had issues with it? Any advice would be much appreciated! https://plus.google.com/u/0/photos/...94953776203759650?authkey=CMzV9PeT0oalcQ
| | | | | Joined: Feb 2018 Posts: 116 Shop Shark | | Shop Shark Joined: Feb 2018 Posts: 116 | Many of you might find this nerdy or excessive but I have made a Chevy themed helmet. My twin brother was the first to make a themed helmet with a Pith. He is a member of Yesterdays Tractor and the Mid Iowa Case Club; so a Case theme was obvious. Well now I have a Chevy theme too! Let me know what you all think. https://plus.google.com/u/0/photos/...7920916204375250?authkey=CJiNo8O_haqswwE | | | | | Joined: Jul 2000 Posts: 173 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 173 | | | |
