1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I was wondering aboout the high temp coatings used on exhaust manifolds, I can't think of the correct name but is it worth it? OF will NAPA 1800 degree paint work OK? | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | I've never seen any of them last too long. But the NAPA will last a lot longer than most. I read somewhere, if you heat the manifold up with a torch from the inside, than paint it, the paint last a lot longer.
I think Jet Hot makes a good header coating that is applied that way.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Thanks Frank, thats the name I was looking for, any experance with them? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Ive had good luck so far with Eastwoods S.S. high temp coating on my manifolds. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Thanks I'll check them out also. | | | | | Joined: Dec 2002 Posts: 3,438 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,438 | i used BBQ paint, but i havent ran the engine yet... If it burns off, then i'll find something else...
| | | | | Joined: Aug 2007 Posts: 14 Apprentice | | Apprentice Joined: Aug 2007 Posts: 14 | I use Krylon High Heat & radiator paint which is good to 1000`F. It's cheap($5.00 can) & comes in several colors. I stock up on sales too. Has been fine on my VW cooling tins which get pretty hot. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I was in Lowes, and found wood stove paint. I don't recall the temps it will withstand, but it fairly high. There were three colors on the shelf. The one I purchased was a dull silver grey. I sand blasted my manifold, and painted it. It looks like cast iron, and has not come off yet. I did this in May I think. Also I haven't run the truck but a couple of times in the last two months, as I was replacing all the glass and rubber in the cab, Plus I repainted the interior, new seat covers and so it goes. Jimmie | | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | ive used jet hot for alot of customer cars never hade a problem with flaking just a little discoloration at sharp bends very close to the header if ther is a sharp bend never on the header i guess a single cylinder doesnt get hot enof by its self | | |
