3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#127914 08/30/2007 3:51 AM
I was wondering aboout the high temp coatings used on exhaust manifolds, I can't think of the correct name but is it worth it? OF will NAPA 1800 degree paint work OK?
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
#127915 08/30/2007 5:33 AM
I've never seen any of them last too long. But the NAPA will last a lot longer than most. I read somewhere, if you heat the manifold up with a torch from the inside, than paint it, the paint last a lot longer.
I think Jet Hot makes a good header coating that is applied that way.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
#127916 08/30/2007 1:29 PM
Thanks Frank, thats the name I was looking for, any experance with them?
#127917 08/30/2007 1:39 PM
Ive had good luck so far with Eastwoods S.S. high temp coating on my manifolds.
1952 Chevy Shortbed
Photos in Photobucket
#127918 08/30/2007 1:52 PM
Thanks I'll check them out also.
#127919 09/06/2007 4:57 AM
i used BBQ paint, but i havent ran the engine yet... If it burns off, then i'll find something else...
Another quality post.
Real Trucks Rattle
#127920 09/07/2007 5:22 PM
Apprentice
Apprentice
I use Krylon High Heat & radiator paint which is good to 1000`F. It's cheap($5.00 can) & comes in several colors. I stock up on sales too. Has been fine on my VW cooling tins which get pretty hot.
#127921 09/07/2007 6:27 PM
I was in Lowes, and found wood stove paint. I don't recall the temps it will withstand, but it fairly high. There were three colors on the shelf. The one I purchased was a dull silver grey. I sand blasted my manifold, and painted it. It looks like cast iron, and has not come off yet. I did this in May I think. Also I haven't run the truck but a couple of times in the last two months, as I was replacing all the glass and rubber in the cab, Plus I repainted the interior, new seat covers and so it goes. Jimmie
#127922 09/08/2007 5:12 AM
ive used jet hot for alot of customer cars never hade a problem with flaking just a little discoloration at sharp bends very close to the header if ther is a sharp bend never on the header i guess a single cylinder doesnt get hot enof by its self
