| | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | I was doing a search on blasting & primer, and found a bunch of different opinions on both. My question is if you're going to blast your fenders, hood, running boards what type of media is best & what should the air pressure be set at?
If it was easy, everybody would be doing it.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | JamesB, I would say a lot of it depends on what your using to do the blasting. Siphon type, gravity feed or pressure pot. Then how well you blast will depend on how consistent and how much air supply you have. Personally I have a pressure pot and I run 100 psi or maybe a tat more if the rust is real bad. I'm running a 7hp 175psi 19cfm air compressor and even it has to "work hard" if I stay at it continually for a spell.(usually until I have to refill the tank) On some of the blasters you will find the "optimum" level as you blast and adjust the sand. Just today I stop at Metromont (concrete place) and picked up 6 more bags of Blasting Sand. It is 100 lb bags at $6.25 a bag. I ask for the FINE which is considered #30. The coarse is considered #12....at least thats whats on the bags I get. I generally use the fine stuff. Once I get through I sift it through a screen and re-use it in the pot blaster or my blasting cabinet. Hope this helps you out and I'm sure you'll get more opinions. | | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 |
