1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#127757 08/23/2007 2:40 AM
I was sent this BB link that someone scanned the written article to on use the electric method for de-rusting. This is great info. Once you get to the BB scroll down to the 5th. post and see the written article with color photos. That's what I will build this weekend.
http://www.jalopyjournal.com/forum/showthread.php?t=167665&highlight=electrolysis
I'll post this at jolly's site and also in the Greasy Spoon and send them this way.
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
#127758 08/23/2007 8:48 PM
I will have to give that a try! Thanks for posting.
#127759 08/28/2007 7:27 PM
Curiosity got me. I am derusting shock and spring brackets using the set up in TECH TIPS with modifications. I have to say it works very well and am surprised as to how well. My charger is a newer digital type and intially wouldn't work. It shut down and kept sending messages about a bad battery cell. So I fooled it by hooking it first to a dead 6V battery and then used copper 14GA copper wire from the battery posts to the discahrge rod and rusted piece. Works like a charm.
Drew
#127760 08/28/2007 11:39 PM
I have not tried that yet, but heard it works better than just the charger.I guess I need to get a battery to use for de-rusting.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
#127761 08/29/2007 4:00 AM
For the folks that are using this process, how long do you need to let this thing cook? Or does it depend on the type of DC source your using?
Is there some way to tell it's done?
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
#127762 08/29/2007 1:40 PM
I let my first shock bracket "cook" for 3 hours
with periodic brushing with a wire brush. I don't think it needed to be in the process that long, but I was painting too, so I just checked it when I had time. It was, by the way, very heavily rusted. Later today I'm putting in the other bracket along with the flat U-Bolt plates all wired together. I'll let you know how long that takes.The nice thing about this process is that it doesn't require a lot of attention so it's almost a side job.
Drew
#127763 08/29/2007 2:20 PM
Anonymous
Unregistered
Anonymous
Unregistered
I have a similar set up just in a 55gal barrel and have had great success on wheels and a bell housing and a few other items I could not get in my blaster cabinet. most of these were then taken out of the tank and scrubbed with a plastic brush and then I cleaned with Por15's marine clean to make sure all the oil and goo was removed then rinsed and shot with metal ready before I primed them. sure works slick. You guys should try it at least once.
Mike
#127764 08/29/2007 4:47 PM
OLTRUCKS,
55 Gallons!Wow! How did you fiqure the proportions of the soda and did it require higher voltage? Never thought about doing wheels.
Drew
#127765 08/30/2007 3:39 AM
The soda numbers stay the same 1-2 oz per gallon so for 55 gallons would need 6.9 lb of Soda I used pH Plus from wal-mart in the pool section $5.00 for about 5 pounds.
It seems to work on the bumper brackets. I used an 18 gallon large plastic container, Next time I will rig up a 5 gallon bucket, I think the "less travel" space between the pos and neg ions may have something to do with the effectiveness of the process.
#127766 08/30/2007 3:04 PM
Yes,I agree that less space between the +/- seems more effective in shorter time. I placed my remaining brackets in a smaller container and the 3 pieces were done in less then 2 hours. I'm going to locate a plastic container that will hold one wheel and see how it works. Thanks for the info.Simple math afterall.
Drew
#127767 08/31/2007 6:53 PM
6 heaven
6 heaven
Hey OLTrucks guy- did you hook up one of the battery cable leads to the 55 gallon barrel and then suspend the parts in it, with their own lead? I hope I have been clear on this question.
#127768 09/07/2007 4:13 PM
Apprentice
Apprentice
I read about this system & set up some parts is a 5gal plastic can with great results. I went out & purchased a large plastic storage bin & now have an assembly line going. Parts waiting are soaked in vineger 1st then are placed into the electroyte bin. If I find an inexpensive charger I'll get it as mine is only 2 amps & I think it would go faster if I use a 10amp system
#127769 09/07/2007 4:27 PM
Anonymous
Unregistered
Anonymous
Unregistered
I had used two leads (steel rods) in the barrel and connected the other lead to the chain the held the wheel (one at a time)suspended with a pipe across the top of the barrel. I used a charger hooked to a battery then to the leads for the tank/item (I had problems with the charger alone). The gap I had between the rods and the wheel was close to 8-10” and it did take about 24 hrs for them to get where I wanted them. After I scrubbed them down with a stiff plastic brush while rinsing them off then hit them with por15”s marine clean then rinsed then prepped with metal ready till I’m ready to paint them they look great. I’m sure some fine tuning can be done and might have faster results.
Mike
#345070 12/05/2007 6:30 PM
OLTrucks
Unregistered
OLTrucks
Unregistered
#345215 12/06/2007 12:08 AM
One thing I would like to point out from that write up. I have read from other sources that stainless steel is very bad to use for this. It produces a highly toxic by-product in the water that is a known cancer causing element. I use steel rebar in mine and it works just fine. I'm not trying to pick apart the write up, just want everyone to be safe.
Electrolysis is the coolest way to derust parts. After letting pearts soak over night most paint is softened up enough that it will come right off with a wire brush and hose. I did from the bellhousing to the rear end on my coe, and all the little parts in between. I just use a 32 gallon trash can but plan on going bigger.
The key is to surround the piece with scrap metal. I hang my parts in the middle and have 10 or more sticks of scrap steel wired around the edge of the trash can.
Heres a pic of the driveline. When done, flip and repeat.
The tranny case came out super clean, did the oil pan, all kinds of stuff. Just take a grinder to the scrap metal once in awhile to clean off the big stuff. Its also worth putting a lid on so you dont end up with drowned rats in the solution.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
YEPPPPPP, there is another post floating around about this w/several sites w/info on how to do it also...Joe
