8 members (Bill Hanlon, MickeyP, papas52, GMCJammer51, tclederman, Phak1, Peggy M, 1 invisible),
100
Mod | | | Forums66 Topics128,169 Posts1,057,031 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2018 Posts: 1 Moderated | | Moderated Joined: Aug 2018 Posts: 1 | Hi guys I just inherited my Grandfather's 1950 Gmc 1 ton grain truck. It has sat for 15 years not running and now i'm trying to bring it to life. I have found some info on other sites and this one as well about the serial numbers and what they mean, but i'm having trouble locating parts for the old girl. It was built in canada so it has a 216 in it. Looking on Rock Auto for parts for it but it lists the motor as a 228. Will the parts for the 228 fit the 216? I need a fuel pump, brake parts, and some spare ignition parts. thanks in advance | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | firstlight, welcome to the Stovebolt. I'm not very informed about Canadian built trucks but you never know what a previous owner, or your granddad, may have switched along the years. I'd double check the numbers and go from there. If its indeed a 235, or 228, then that is the engine to buy parts for. There are other GMC members here that can help.
Since this is the Welcome Center I'd suggest posting questions in the best forum. Engine questions in the Engine Forum and driveline questions in the driveline forum and paint, well ask those in the paint and body forum.....You will get faster and more answers that way. Be sure to watch for your Canadian friends. They are here. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | GMC 1948 1 ton truck - original engine 228 in USA 216 in Canada Welcome to Stovebolt.com
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Welcome to Stovebolt.com
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 |
Welcome to the site. If it is Canadian built, it will have Chevy power. Some auto parts stores have the US parts catalogues or the engine may have been swapped. As mentioned, just run the engine casting number and find out for sure. Leo | | | | | Joined: Sep 2011 Posts: 131 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 131 | As others have pointed out Canadian GMC trucks had Chevrolet drive lines. So a inquiry for GMC info. will turn up US spec stuff.
There is good information from folk that have Cd. knowledge on this site. Some of us have GM of Canada service and parts books. No reprints for these.
Is your truck a single wheel? or Dual wheel? In 50 the brakes were still Huck brand, Drums will be hard to find. Bendx came in a year for light units and another couple for the larger trucks. If your engine is tired, a full pressure 235 or 261 would be a wise improvement. Look for a Cdn. Pontiac six.
Keep those One Tons rolling! Lots in Alberta. Howie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine 4 1966 Plymouth VIP 5.7 GenIII Hemi 5 1966 Imperial Crown Coupe 440 engine | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | If you’ve indeed checked your number on the engine and you’re sure you have a 216, good on ya. However, I just assumed (no checking) I had a 216 in my one ton and turns out it was a low pressure 235. The Big Bolts up in Canada tended to use GMC engines, whereas 1 tons and down used Chevy power. I love my 1 ton GMC with its newly rebuilt 261. Howie makes a good point. Also, check in Chev big bolts from 57-62 for the 261. That’s where I got mine. CHeck out the tech tip in the links. Welcome to the Bolt. You officially have the worm! 😎 | | |
