4 members (moparguy, Pete O, Oswald, Bill Hanlon), 80 guests, and 3 robots.
Topics128,168
Posts1,057,025
Members48,458
Moderated
Moderated
Hi guys I just inherited my Grandfather's 1950 Gmc 1 ton grain truck. It has sat for 15 years not running and now i'm trying to bring it to life. I have found some info on other sites and this one as well about the serial numbers and what they mean, but i'm having trouble locating parts for the old girl. It was built in canada so it has a 216 in it. Looking on Rock Auto for parts for it but it lists the motor as a 228. Will the parts for the 228 fit the 216? I need a fuel pump, brake parts, and some spare ignition parts. thanks in advance
firstlight, welcome to the Stovebolt. I'm not very informed about Canadian built trucks but you never know what a previous owner, or your granddad, may have switched along the years.
I'd double check the numbers and go from there. If its indeed a 235, or 228, then that is the engine to buy parts for.
There are other GMC members here that can help.
Since this is the Welcome Center I'd suggest posting questions in the best forum. Engine questions in the Engine Forum and driveline questions in the driveline forum and paint, well ask those in the paint and body forum.....You will get faster and more answers that way. Be sure to watch for your Canadian friends. They are here.
GMC 1948 1 ton truck - original engine
228 in USA
216 in Canada
Welcome to Stovebolt.com
Welcome to Stovebolt.com shake
Leo Offline
Moderator
Moderator
Welcome to the site. If it is Canadian built, it will have Chevy power. Some auto parts stores have the US parts catalogues or the engine may have been swapped. As mentioned, just run the engine casting number and find out for sure.
Leo
As others have pointed out Canadian GMC trucks had Chevrolet drive lines. So a inquiry for GMC info.
will turn up US spec stuff.
There is good information from folk that have Cd. knowledge on this site.
Some of us have GM of Canada service and parts books. No reprints for these.
Is your truck a single wheel? or Dual wheel? In 50 the brakes were still Huck brand, Drums will be hard to find.
Bendx came in a year for light units and another couple for the larger trucks.
If your engine is tired, a full pressure 235 or 261 would be a wise improvement. Look for a Cdn. Pontiac six.
Keep those One Tons rolling! Lots in Alberta.
Howie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
Big Bolt Forum Moderator
welcome to the site!
Mike
Fox Offline
If you’ve indeed checked your number on the engine and you’re sure you have a 216, good on ya. However, I just assumed (no checking) I had a 216 in my one ton and turns out it was a low pressure 235. The Big Bolts up in Canada tended to use GMC engines, whereas 1 tons and down used Chevy power. I love my 1 ton GMC with its newly rebuilt 261. Howie makes a good point. Also, check in Chev big bolts from 57-62 for the 261. That’s where I got mine. CHeck out the tech tip in the links. Welcome to the Bolt. You officially have the worm! 😎
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
