0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | Has anyone ever tried using a piece of marine-grade plywood that fits a stovebolt bed, and simply cutting precise grooves with a router to accommodate the metal hold-down strips? I've never done it, but it would seem to be a viable alternative to hassling with multiple pieces of wood, and unless someone is some sort of anal-retentive purist, the end result would seem to be the same. I'm suggesting marine-grade plywood rather than exterior because marine plywood has no voids anywhere, while plain old exterior can expose openings that could trap moisture when being cut to fit. The glue is supposedly the same (waterproof) but marine ply is designed to stay wet for extended periods of time.
Just a thought- - - - -comments? Jerry
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Jerry, yes it has been done. Saw it several years ago on one of the car/truck shows on TV. Too long ago for me to remember which one.
| | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | F@#d stepsides in 80's were born that way. | | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | Jerry -- I did my '39 bed that way ...
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | My buddy has a panel truck and it has the original plywood bed with the bed strips on it. The older panels (not sure what years) had wood like the pickups, but there was an issue with exhaust fumes coming through the cracks. BTW, there is no need to for creating any grooves in the plywood. The bed strips will lay flat on the plywood. Carl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As Carl posted:
In 1950, “. . . the floor boards of panel and canopy express models were changed to plywood construction. In the new construction a single panel of wood and five skid strips replaced thirteen floor boards and twelve skid strips. The new floor was positively sealed against dust leakage and the plywood made the floor 25 to 30% stronger than the former construction.” (from an article in the light commercial vehicle association, 1984) | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | The hard part will be to find a sheet of plywood over 48" wide and 6 or 8 feet long.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Order the oversize at your local lumber yard......Lowes/Home Depot. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Or, if a boat repair shop is nearby (or, if your lumber yard is flexible/helpful), get a large enough sheet of appropriate thickness marine ply/grade plywood.
| | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | I did it five years ago when I first started with my 55.1 3600. I used a standard marine plywood from home depot (48"x96") cut it into four pieces (two at 6 3/4 " and two at 16 3/4") I only had enough rotten metal strips to make three complete strips. no grooves and no sealer because it was supposed to be temporary. five years later and outside in New York weather every night and day and used for light cargo with leaves and bird droppings and never washed I can honestly say I'm impressed with how well it held up | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | With the bedside strips welded in place. I would rip the plywood into 2 parts. It would make the install a bit less frustrating.. The gap in the middle would be covered by the normal metal strip and no one would ever know.
Steve H
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | I actually like Jerry’s idea. If you’re not a purist, and you’re just looking for performance and durability, a sheet of stained marine plywood would work really well. 52Carl says there’s no need to route the grooves ‘cause the strips will lay flat. If that’s the case then that’s an extra bonus!
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Nov 2004 Posts: 2,401 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,401 | Without grooves, the metal strips will be on top of and therefore sitting above the wood. Seems to me that the strips should be either flush or slightly below the bed wood.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | I really like this idea. I might have to steal it. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Seems to me that the strips should be either flush or slightly below the bed wood.
John Why would that be? Aren't the strips designed to protect the wood while sliding cargo in and out? Carl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | So the question may remain as to why is the bed wood of the pickup trucks notched for the bed strips? My guess is to contain the edges of wood, preventing separation from shrinkage during dry weather. Why would GM notch the plywood beds? Maybe to maintain the exact distance between the top of the strips and the plywood so that it looks just like a pickup bed?
| | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | This may be a bit late in the conversation, but if you look at the way the notches and strips mate, I suspect that they are made they hold down the planks but allow expansion and contraction so they don’t warp. Just my 2 cents.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Apr 2017 Posts: 40 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 40 | WOW, love this site! I was planning on oak from a logger in the fam. $100.00 would have been a bit much for my 40' Midwest, prior resto, dirt road beater! I'm going with the ply-board. I was thinking 5/4ths deck boards as an alt. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I was thinking of using marine grade plywood to build a slide out using casters in the metal strips so I would not have to crawl under the bed cover to retrieve things that I have in the bed. I bought low profile casters for another project that did not work out.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
