| | | Forums66 Topics128,113 Posts1,056,277 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 7 New Guy | | New Guy Joined: Jun 2018 Posts: 7 | I have a 350 V-8 in my 1963 C-10. There's about 18" between the radiator and back of the fan. Haven't had any problems with cooling yet, but would like to buy a shroud to promote good airflow through the radiator. Any advice on sources for aftermarket shrouds would be much appreciated.
Bill 1963 C-10 Stepside Longbed 350 V-8, 5-speed manual Full-time Rver living in my motorhome
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | The Truck Shop has them in their catalog. Also, check the aftermarket suppliers listed on this site. Fred
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If our traveling and near Charlotte N.C. the Truck Shop has a place there in Concord, N.C. just a mile of I-85.... same exit to Charlotte motor speedway. Stop in and tell them I said hi. | | | | | Joined: Jun 2018 Posts: 7 New Guy | | New Guy Joined: Jun 2018 Posts: 7 |
| | | | | Joined: Jul 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 43 | I just bought a shroud from Classic Parts. It was the cheapest I could find at $109. I am waiting on the shroud seals for the side baffles so I can install it, but it looks like it'll work perfect. I have a Chevy 350 w/ a long water pump and a manual fan. (1964 C10) Janine | | | | | Joined: Jul 2010 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 43 | I installed the fan shroud from Classic Parts. Like everything else that's after-market it had to be modified to fit, meaning... I had to drill holes in it to line up with where the clips fit and I had to cut out a notch on each bottom corner to clear the shroud brace. It was a bit of a pain to get it in, since I had already attached my battery tray, but I got 'er done. Janine | | |
