| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Anyone know of a quality shop that rebuilds old pressure plates.....in this case its for a 1937 Chevy 1/2 ton pickup. I'm trying to help an 84 year old gentleman get his going. A name, company, phone number.... if you have knowledge we need to tap into it.
Thanks for any responses. | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Here is an old school "clutch & brake" shop that I have used. Clutch Specialty Auto Parts A Division of A&G Friction, LLC 944 Murphy Avenue Atlanta, GA 30310 Call: 404-753-6686 [email protected]Give them a try, if they can't help you, they may know someone that can. Good luck SimS | | | | | Joined: Jan 2016 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 40 | If you have no luck with that one try these guys. It has been in business for YEARS and they rebuild all types. I've used them many times. Unique Automotive 693 West Booneslick Rd Jonesburg, MO 63351 636-488-5242 / 636-488-5469 fax http://www.uniqueclutches.comGood luck
Larry
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Alvin,
My '36 Chevy pickup has a "hair trigger" clutch engagement and I understand that problem wasn't solved until the 1938 model year. I really have to pay attention to get smooth clutch engagement. There is no progressive feel to it. If I had the restoration to do over I'd adapt a late model pressure plate onto the '36 flywheel. I have a 1971 Dodge van that bought new and its clutch engagement has always been silky smooth. Even from a stop on a steep uphill the clutch is perfectly smooth and easy to operate.
I'd find a modern pressure plate the right diameter and use that. Your friend should also resurface the flywheel while it's accessible.
Ray
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Thanks to all of you that responded.
Sent the info to Truman and just got off the phone with him. He is so very pleased to have the info. He was, or has been, so frustrated over that. Now he can sleep better tonight because of those willing to help.
Thanks to Stovebolters everywhere. | | |
