0 members (), 177 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
Anyone know of a quality shop that rebuilds old pressure plates.....in this case its for a 1937 Chevy 1/2 ton pickup.
I'm trying to help an 84 year old gentleman get his going. A name, company, phone number.... if you have knowledge we need to tap into it.
Thanks for any responses.
Here is an old school "clutch & brake" shop that I have used.
Clutch Specialty Auto Parts
A Division of A&G Friction, LLC
944 Murphy Avenue
Atlanta, GA 30310
Call: 404-753-6686
[email protected]
Give them a try, if they can't help you, they may know someone that can. Good luck
SimS
If you have no luck with that one try these guys. It has been in business for YEARS and they rebuild all types. I've used them many times.
Unique Automotive
693 West Booneslick Rd
Jonesburg, MO 63351
636-488-5242 / 636-488-5469 fax
http://www.uniqueclutches.com
Good luck
Larry
Y
yar Offline
Y Offline
Alvin,
My '36 Chevy pickup has a "hair trigger" clutch engagement and I understand that problem wasn't solved until the 1938 model year. I really have to pay attention to get smooth clutch engagement. There is no progressive feel to it. If I had the restoration to do over I'd adapt a late model pressure plate onto the '36 flywheel. I have a 1971 Dodge van that bought new and its clutch engagement has always been silky smooth. Even from a stop on a steep uphill the clutch is perfectly smooth and easy to operate.
I'd find a modern pressure plate the right diameter and use that. Your friend should also resurface the flywheel while it's accessible.
Ray
Thanks to all of you that responded.
Sent the info to Truman and just got off the phone with him. He is so very pleased to have the info. He was, or has been, so frustrated over that. Now he can sleep better tonight because of those willing to help.
Thanks to Stovebolters everywhere.
