3 members (Paul Mullen, JW51, GrandpasJimmy), 96 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
Page 2 of 2 1 2
I need the Chevy Loadmaster emblems. Does anyone have leads on where I could get a pair?
Post a want ad in the Swap Meet Forum.🛠
Be sure to put the year in your Want Ad.
Thanks for the help guys!
So update on the progress. All base coats for the frame, bumper and rear wheels are complete. Pictures are linked below. There is a picture of the wheel seals and the heater.
1. Do they make those anymore or will I have to make them myself with gasket paper? Same with the rear differential?
2. Does anyone know anything about the heater? Is it really "deluxe"?
https://plus.google.com/u/0/photos/...70878278511119986?authkey=COzjjf6n__eUZA
Great thread. Inspiring.
Stuff I’m gonna work on, I swear
1963 C30 flatbed
1961 Apache 30 (parts, no title)
1960 GMC Big Bolt
Don't tweet, face, Google, or link. Just hanging in as long as I can...
So an update! Rear end has been put back together and wheels have been mounted. Put the hoist back on the frame and will start work on the box and front end. Pictures are linked below!
https://plus.google.com/u/0/photos/...8828462337772210?authkey=CKDll9qnqvz_kgE
Looking good!
Cool old Case tractor you have there!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Thank you Rich. It's my twin brothers. He has old Case tractors and I have old Chevy trucks. We can both go bankrupt together. ha ha!
So today I have been working on the front end and split the xmsn from the engine. I have a few questions. 1948 6100/6400
1. I have a mid 50s 235 that I am honing and putting new rings in. I also have the SM420 XMSN with it. If I got a SM465; would it bolt right in where the 420 was? No modifications to the engine/bell housing/truck frame? A "turn key" operation.
2. The truck had a hydrovac brake booster on it originally. Is it worth it to spend the time and money to have it rebuilt and reinstall it or just hook the brakes up the way they are now? How much of a difference does the booster make?
Pictures linked below.
https://plus.google.com/u/0/photos/...83827133312247138?authkey=CKmh3KLYotmIVA
I see you have a PTO on your SM420, does the SM465 have a PTO? If not you need to confirm the one on the SM420 will work on the 465...that could be a deal breaker if you intend on using it.
The Hydrovac will triple the line pressure you make with your leg...why wouldn't you want that? If you generate 500 psi, the Hydrovac adds 1000 psi more!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Im pretty sure the PTOs interchange. Am I wrong?
So the past few days have been exciting. We retrieved the "new" parts truck and brought it home. Pictures linked below. Does anyone know anything about the radio in it? I believe it is a Philco Radio.
https://plus.google.com/u/0/photos/...9366560098885026?authkey=CJ6-vfT90oXazAE
Also, my twin brother brought home a Case A6 combine. He is not planning to restore it. Just get it functional and run as is. It should go well with the 10ft Omaha Standard box on the truck. Pictures posted below.
https://plus.google.com/u/0/photos/...9366172691780386?authkey=CNSwmJncxIb9yAE
What's the radio control head look like? Is the speaker in the dash?
Neat old combine!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Big Bolt Forum Moderator
sweet!! Thanks for sharing the pics!
Mike
Thanks! I'm not sure where the speaker is. I will try and look tomorrow. I think in the box?
My guess is the box is just the tube chassis and there is a remote speaker and control head.
If you remove the radio cover you may find a date stamped somewhere inside the box. It looks older than the truck to me...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Hey everyone. Its been another couple busy days. I found and pulled (with the owners help) a 1950s GMC 270 to replace the 235 in my truck. Any tips or tricks I should know of for the swap? Pictures linked below.
https://plus.google.com/u/0/photos/...90469239888399442?authkey=CPbZsOfAo7KCbw
Crusing in the Passing Lane
GMC engines are about 3" longer than Chevy's, so, you will need to allow for that, GMC's move the radiator FWD in the core support.
PTO's are transmission specific, so a 420 PTO may or not fit a 465. Since you have both. Straight cut vs. 'slanted' cut gears and also depth in the gears(shims are available to depth of engagement) are some issues. I am sure there are PTO shops in IA.
Ed
Thank you Ed! Does that 3" mean that I will have to modify the firewall or just have to move the radiator forward 3"?
I need help everyone. I was about to throw a wrench today. I ordered a new steering box bushing/seal kit for the horizontal shaft. I cannot get the new seal to fit over the splined shaft. Has anyone done this or had issues with it? Any advice would be much appreciated!
https://plus.google.com/u/0/photos/...94953776203759650?authkey=CMzV9PeT0oalcQ
Onto better news. I installed the 270. Like Ed said; it was just shy of fitting in the front mount. I will have to make a custom mount. It has good cylinder and oil pressure. Link to pictures is below.
https://plus.google.com/u/0/photos/...4954647933287938?authkey=CJTwmoDDhoLJsgE
Many of you might find this nerdy or excessive but I have made a Chevy themed helmet. My twin brother was the first to make a themed helmet with a Pith. He is a member of Yesterdays Tractor and the Mid Iowa Case Club; so a Case theme was obvious. Well now I have a Chevy theme too! Let me know what you all think.
grin
https://plus.google.com/u/0/photos/...7920916204375250?authkey=CJiNo8O_haqswwE
Awesome!
Cheers, Dean
Dean 'Rustoholic' Meltz
Lurch: 1927 1-Ton Chevy Cattle Truck
Old and ugly is beautiful! -- The Saga
Lurch's Gallery
Justin: 1928 Chevrolet AB Canopy Express
Hello everyone! So a long overdue update about the old truck. Painted the sides of the flatbed and got it welded to the hoist. I was a little hesitant about crawling under the box raised so I made a hoist safety lock. Pictures linked below.
I'm also posting a link to yesterdays tractor where my brother has posted about the Case auger wagon we built. Its a fun little project. It should be able to dump into the truck when finished.
Truck pictures:
https://plus.google.com/u/0/photos/...8197828125016546?authkey=CJTx1_mLjf6muwE
Case auger wagon pictures:
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=case&th=324551
Page 2 of 2 1 2
