0 members (), 129 guests, and 3 robots.
Topics128,193
Posts1,057,258
Members48,466
SiG
Offline
Need tires for my 1949 Chevy 3600, still have the old 8 lug split rims with 235/75/15 tires mounted. This is a daily driver, most weeks I drive at least a 100 miles, what would be the best tire size to buy ? and should I replace the split rims? If so with what? Thanks!
SiG, did you do a search within Stovebolt.com? This topic has been hashed to death hundreds of times. You should find lots of opinions. Btw, I personally don't like split rims but to each his own. Good luck.
I purchased 4 Dexstar AM20766 Rims for my 1954 3600. These are 16" x 6" rims with 8 holes and have the +.5" offset so you clear the tie rod ends. They work great. LT 215 / 85R16 will get you very close to the original tire diameter. Dexstar wheels are available from www.etrailer.com Good luck.
Ron - - Dusty53
1954 Chevy 3604
Fox Offline
I'm looking at these rims for my 1 ton 1950. Looks like the perfect solution. I have a couple questions:
1. Does this tire and rim combo and size "look" as right as my 7.5x17 1ton tires?
I'm also curious as to using the original clips for the hubcaps on the new rim. Is it advisable to drill holes in to the rim in order to mount the clips? Or better to weld them on?
Might be a silly question but I'd hate to wreck a rim by drilling and would as much hate to wreck a perfect black powder coat just to install some clips by welding.i have all the hubcaps for this truck and don't need to purchase new ones.
Thanks for the input.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Fox Offline
Has anyone out there experience with these questions?
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
I went through the same delemma. Since my rear tires were like new I started calling arround to see what I could get. Most places couldnt get 7.50-17 tires, and one told me that he has installed 235/80R17 tires on old Chevys and they work out fine. I finally found a place that could get me Samson Traker Plus Highway tires in 7.50-17 for $193 each (Canadian dollars) and bought them. If you are in the US Summit racing sells the Coker tires, but shipping to Canada was to expensive for me.
Fox,
Been doing a lot of searching on this. Decided to bite the bullet and go for the Excelisor stahl sport radial with tubes by Cooker tire. Almost the exact profile as the stock bias ply but in radial, with the nastalga look. Only setback is cost. Also it's not a working truck anymore. But it should be the last set of tires this truck will ever see.
Still enjoy watching your progress!!! Looks great! Nice work
Take care
Jim
~ Jim Schmidt, Bucks County, PA
1953 Chevrolet 3804 1-ton
In the DITY Gallery
Fox Offline
Thanks fellas.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Got them mounted up. Exactly the look I wanted.
tires
I have a 1954 chevy 3600, I need help on tires. My front tires are 215/85/16 it is tight. I wonder if I put on 215/65/16, will that be better for road worthy. I use the truck for only light work.
What does "it is tight" mean?
I'm running 215/85/16 tires on my 51 3600. Never a problem in almost 10,000 miles. No rubbing or bumping even with 2,000 lbs of hay in the bed.
RonR
1970 340 Duster
1964 CJ5
Thank you you are right no real issues with how it rides just concerns.
