| | | Forums66 Topics128,181 Posts1,057,187 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 49 | Need tires for my 1949 Chevy 3600, still have the old 8 lug split rims with 235/75/15 tires mounted. This is a daily driver, most weeks I drive at least a 100 miles, what would be the best tire size to buy ? and should I replace the split rims? If so with what? Thanks! | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | SiG, did you do a search within Stovebolt.com? This topic has been hashed to death hundreds of times. You should find lots of opinions. Btw, I personally don't like split rims but to each his own. Good luck.
| | | | | Joined: Jul 2014 Posts: 1,293 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,293 | I purchased 4 Dexstar AM20766 Rims for my 1954 3600. These are 16" x 6" rims with 8 holes and have the +.5" offset so you clear the tie rod ends. They work great. LT 215 / 85R16 will get you very close to the original tire diameter. Dexstar wheels are available from www.etrailer.com Good luck.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | I'm looking at these rims for my 1 ton 1950. Looks like the perfect solution. I have a couple questions: 1. Does this tire and rim combo and size "look" as right as my 7.5x17 1ton tires? I'm also curious as to using the original clips for the hubcaps on the new rim. Is it advisable to drill holes in to the rim in order to mount the clips? Or better to weld them on? Might be a silly question but I'd hate to wreck a rim by drilling and would as much hate to wreck a perfect black powder coat just to install some clips by welding.i have all the hubcaps for this truck and don't need to purchase new ones. Thanks for the input. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Has anyone out there experience with these questions? Thanks
| | | | | Joined: Aug 2014 Posts: 15 New Guy | | New Guy Joined: Aug 2014 Posts: 15 | I went through the same delemma. Since my rear tires were like new I started calling arround to see what I could get. Most places couldnt get 7.50-17 tires, and one told me that he has installed 235/80R17 tires on old Chevys and they work out fine. I finally found a place that could get me Samson Traker Plus Highway tires in 7.50-17 for $193 each (Canadian dollars) and bought them. If you are in the US Summit racing sells the Coker tires, but shipping to Canada was to expensive for me. | | | | | Joined: Feb 2013 Posts: 614 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 614 | Fox, Been doing a lot of searching on this. Decided to bite the bullet and go for the Excelisor stahl sport radial with tubes by Cooker tire. Almost the exact profile as the stock bias ply but in radial, with the nastalga look. Only setback is cost. Also it's not a working truck anymore. But it should be the last set of tires this truck will ever see. Still enjoy watching your progress!!! Looks great! Nice work Take care Jim | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | | | | | | Joined: Aug 2014 Posts: 15 New Guy | | New Guy Joined: Aug 2014 Posts: 15 | Got them mounted up. Exactly the look I wanted. tires
| | | | | Joined: Jun 2016 Posts: 2 New Guy | | New Guy Joined: Jun 2016 Posts: 2 | I have a 1954 chevy 3600, I need help on tires. My front tires are 215/85/16 it is tight. I wonder if I put on 215/65/16, will that be better for road worthy. I use the truck for only light work.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What does "it is tight" mean? | | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | I'm running 215/85/16 tires on my 51 3600. Never a problem in almost 10,000 miles. No rubbing or bumping even with 2,000 lbs of hay in the bed.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Jun 2016 Posts: 2 New Guy | | New Guy Joined: Jun 2016 Posts: 2 | Thank you you are right no real issues with how it rides just concerns. | | |
