0 members (), 192 guests, and 0 robots.
Topics128,089
Posts1,056,143
Members48,436
Page 1 of 2 1 2
#1265645 05/13/2018 2:06 AM
have a 1952 chevy 1 ton pickup. trying to put newport motor in. my question does it go inside or outside of bracket. anyone have a pic. i am having a hellva time with this thanks
I have the one that clears the choke cable
thank u. i have the one that clears choke cable also. it just don't want to sit in bracket. i been working on this 2 days and i hear it's a simple job
dad do u have pics of the whole setup. i see u did on another page but when i click on it, i get error 404
I used the Newport in my 52 panel and it works great.
Jimbo, I started to chime in after you posted but I didn't take one of it under the dash and probably can't till Monday. You'll probably have it figured out by then? I'll watch this thread.
I have mine parking right but it only wipes about 3/4 of the way to the outer edge of the windshield.. I did not do any adjustments, yet, but it sounds like maybe you can do a little???
Insomniac
Insomniac
I have seen comments about the Newport wiper motors not wiping the whole windshield. This video of a guy putting one in an Olds seems to show that (skip to the end to actually see the wiper work):
YouTube video
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Unable to share the album for some reason
Here a a few more pics
...click...
...click...
...click...
It should fit
Only problem I had was I installed the transmission arm wrong at one point
ok, i think i had it in backwards
FROM FRONT SEAT
...click...
nice dash
Thank you
Rattle can finish, 8 years old and still holding up well.
I was trying to show the wiper motor in that pic, you can see the way its positioned
dad sorry i'm so boneheaded. got the motor in but how does bracket go in
also, is there anything to heep from old motor. what is that piece on wiper arms.
I don’t have a good pic of the bracket I think your talking about. If it’s the black z shape bracket that came with the kit, it attaches to the brace
...click...
You reuse the transmission arms
That spring thing in the other pics is the original keeper from the trico
i think that bracket is already there. is this right Dad[img]http://[/img][img]http://[/img][img]http://[/img][img]http://s1296.photobucket.com/user/cuz2424/media/Chevy/20180514_180102_zps2dsnkkle.jpg.html?filters[user]=136730829&filters[recent]=1&filters[publicOnly]=1&sort=1&o=0[/img]
http://i1296.photobucket.com/albums/ag3/cuz2424/Chevy/20180514_180102_zps2dsnkkle.jpg i think i have the bracket already there Dad. is that right
looks like the original
if it the same as the one that came in the newport kit, then your in good shape.
thumbs_up
ok looks just like it. now i just put the arms on with washers and that's it
Don’t forget the E clips
Should of came in the kit
...click...
got it thanks again. then later the switch. o boy
i did it. can't believe it. thanks to u Dad. ? my wipers don't go back all the way. do i have to take arms off or is there a adj. somewhere
Just make sure the arms are on correctly. There is a wrong way
....this is the wrong way.....
i think I did have to adjust the park.
I don’t remember how I did it. I think there was an Allen screw on the hub you can reposition?
Anyone?
why is that incorrect. my drivers side fell off a couple of time but now ok i think
Here is correct
...click...
Notice where the long transmission arm is between the two pics
i think mine is wrong way. how do i move motor arm
any help
Are you talking about adjusting the park?
Or just simply moving the arm on the motor that the two wiper transmission arms attach to?
Do you have a pic?
arm on motor so they look like your second pic
Sorry jimbo
Maybe im not understanding
If you want to change positions of the arms simply disconnect them from the motor ane switch them
If its something else let us know.
its hard to tell , but the arms appear backwards
Hard to explain
Try switching them
Youll know right away
ok Dad, i must be brain dead. the wipers go three quarters up and three quarters down. the v groove in wiper arm is facing almost down, maybe a little towards seat.
Not sure whats going on with that
Try calling newport
They are very helpful and give good tech advice
Make sure you let them know what model # you have
They have two models for the A D trucks
just scroll back and forth. there r a couple of good pics
Dad check this out. I built this truck from top to bottom. i put in windows[
(that were hard) headliner and alot of things. This wiper motor was the hardiest thing i put in. And i'm still not right. I loosened the set screw on the motor arm. Moved it a little, i thought i had it. Now my passanger wiper goes all the way back. Fine The drivers side does half the window. What is wrong. I thought this thing was a perfect switch.
Hopefully someone will chime in with an idea
Tomorrow fter work ill try to get a video of the newport at work
Check for binding in transmissing arms in the mean time
Hang in there
Page 1 of 2 1 2
