5 members (Rmillerfly, Shaffer's1950, 52GMC35424JD, FAST55, 1 invisible), 76 guests, and 2 robots.
Topics128,050
Posts1,055,757
#1265596 05/12/2018 2:39 PM
Can someone suggest a vendor or source for the brass fitting, hollow bolt and brass washers at the back of the master cylinder. Truck is a ‘53 3100. Thanks for any help.
'53 3100 Short Bed
Texas Peace Officer - supporter of the Badge and the Blue Line
Pain is part of life, Misery is an option.
Are you missing the pieces or just want to replace? Ordinarily, the brass fitting and the hollow bolt (called a banjo bolt) can be reused. What you call brass washers are copper and it is best to replace these (you can heat these to anneal so they are soft again to allow a good seal). I think a NAPA store or other auto parts store would have these. You would have to be sure the flare fitting on the brass block will be the correct size for your brake line. If you don't have the original parts, take the master cylinder and know what size your brake line is and go to the store to be sure you have a match.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
It appears the fitting and the banjo bolt are okay but I think both copper washers are not sealing. I’ll be in a town with a Napa store next week and will try that. Thanks for your response.
'53 3100 Short Bed
