| | | Forums66 Topics128,057 Posts1,055,815 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 75 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 75 | Can someone suggest a vendor or source for the brass fitting, hollow bolt and brass washers at the back of the master cylinder. Truck is a ‘53 3100. Thanks for any help.
'53 3100 Short Bed Texas Peace Officer - supporter of the Badge and the Blue Line Pain is part of life, Misery is an option.
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Are you missing the pieces or just want to replace? Ordinarily, the brass fitting and the hollow bolt (called a banjo bolt) can be reused. What you call brass washers are copper and it is best to replace these (you can heat these to anneal so they are soft again to allow a good seal). I think a NAPA store or other auto parts store would have these. You would have to be sure the flare fitting on the brass block will be the correct size for your brake line. If you don't have the original parts, take the master cylinder and know what size your brake line is and go to the store to be sure you have a match. | | | | | Joined: Feb 2014 Posts: 75 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 75 | It appears the fitting and the banjo bolt are okay but I think both copper washers are not sealing. I’ll be in a town with a Napa store next week and will try that. Thanks for your response.
