0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1264126 04/30/2018 1:59 PM
Leo
Offline
Moderator
Moderator
Yesterday this issue began. My driver side door window starts to wind down on its own. In 5 minutes of driving it's down about half an inch. The glass fitment is good and I haven't had issues with it until now. Where do I start to look?
Leo #1264130 04/30/2018 2:35 PM
V
VEW Offline
V Offline
Hey Leo,
You won't worry about that when it's warm out; but when it's 38 degrees, like on your trip home, it can be a bit cold (especially with no heater).
As you know, I'm not a AD owner, but seems like your regulator return/counter spring (don't know if it's called that) is failing. I'm sure one of the AD guys will let you know.
Nice to see you at HC and to hear you had a good trip back!
~ Victor
1957 3100 - moved on
Leo #1264241 05/01/2018 3:21 AM
Carl52 would tell you to hang a brick on it.......I tell you to ride with your knee under the door handle!!
Leo, not on my panel but a pickup years ago I had the same problem. Time to replace, or repair, the regulator. (at least it fixed my problem)
