3 members (TUTS 59, Jon G, Joe H),
97
Mod | | | Forums66 Topics128,026 Posts1,055,402 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 |
Yesterday this issue began. My driver side door window starts to wind down on its own. In 5 minutes of driving it's down about half an inch. The glass fitment is good and I haven't had issues with it until now. Where do I start to look? | | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Hey Leo, You won't worry about that when it's warm out; but when it's 38 degrees, like on your trip home, it can be a bit cold (especially with no heater). As you know, I'm not a AD owner, but seems like your regulator return/counter spring (don't know if it's called that) is failing. I'm sure one of the AD guys will let you know. Nice to see you at HC and to hear you had a good trip back!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Carl52 would tell you to hang a brick on it.......I tell you to ride with your knee under the door handle!!
Leo, not on my panel but a pickup years ago I had the same problem. Time to replace, or repair, the regulator. (at least it fixed my problem) | | |
