3 members (Gdads51, Raymond HAYWOOD, IHPWR), 175 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
I'm not much of an engine guy so I'm hoping you can advise me. I bought a 58 Chevy with a 350 SBC actually built and represented to me as a 383. I replaced the intake gasket for leak and rebuilt 4 barrel etlebrock carb, got her running but when I went to set timing ,,,,no timing tab indicator. Ugg I looked on line and found that there are more options than I can weed though. I'd like ro just put on an OEE tab indicator. What do you engine guys say? What do I need? It has a EI distributor. Does the original bolt on engine Block off to drivers side ( two bolt holes there ) or timing cover bolts. Thanks for any help. Pete
The 1958 TRI-FECTA
Stepside, Fleetside and Cameo
More Fleetside pix
More Cameo pix
More Apache Stepside pix
There is a way to time it but I'll let HRL explain it better than I can!!!
Y
yar Offline
Y Offline
Pete,
An original style timing tab will get 'er done. Here's how to find top dead center:
https://www.speedwaymotors.com/the-toolbox/locating-top-dead-center/28657
The tool for doing that is easily made from a spark plug with the porcelain removed and the plug threaded for a bolt that will contact the top of #1 piston as you gently rotate the engine by hand. The marks can be made on a degree wheel, timing tape or the balancer itself. Easy, peasy!
Ray
Thanks guys. Where does the original tab bolt on on a 350 block and what's the best source for the OE M tab ?
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
The pointer will depend on the damper installed, there are 2 diameter used. Also 2 different locations for indicator (pointer) on timing cover depending where the line on the damper is in relation to the keyway.
BC
1960 C60 pasture art
Y
yar Offline
Y Offline
"Where does the original tab bolt on on a 350 block and what's the best source for the OE M tab ?"
Pete,
It's attached by the screws that hold the timing cover to the front of the block. If you PM me your email address I'll send you a photo of the one on the 350 in my '32 Ford roadster street rod. A lot of street rod builders are into bling and throw away the OEM tabs. I'm sure you can find one for the cost of postage. If I had an extra one I'd send it to you. It's not as though they wear out.
If you get on the Chevy Talk forum it's pretty likely someone would have one for you.
Ray
