| | | Forums66 Topics128,089 Posts1,056,010 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | I'm not much of an engine guy so I'm hoping you can advise me. I bought a 58 Chevy with a 350 SBC actually built and represented to me as a 383. I replaced the intake gasket for leak and rebuilt 4 barrel etlebrock carb, got her running but when I went to set timing ,,,,no timing tab indicator. Ugg I looked on line and found that there are more options than I can weed though. I'd like ro just put on an OEE tab indicator. What do you engine guys say? What do I need? It has a EI distributor. Does the original bolt on engine Block off to drivers side ( two bolt holes there ) or timing cover bolts. Thanks for any help. Pete | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | There is a way to time it but I'll let HRL explain it better than I can!!! | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | Pete, An original style timing tab will get 'er done. Here's how to find top dead center: https://www.speedwaymotors.com/the-toolbox/locating-top-dead-center/28657The tool for doing that is easily made from a spark plug with the porcelain removed and the plug threaded for a bolt that will contact the top of #1 piston as you gently rotate the engine by hand. The marks can be made on a degree wheel, timing tape or the balancer itself. Easy, peasy!
Ray
| | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | Thanks guys. Where does the original tab bolt on on a 350 block and what's the best source for the OE M tab ? | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | The pointer will depend on the damper installed, there are 2 diameter used. Also 2 different locations for indicator (pointer) on timing cover depending where the line on the damper is in relation to the keyway.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | "Where does the original tab bolt on on a 350 block and what's the best source for the OE M tab ?"
Pete,
It's attached by the screws that hold the timing cover to the front of the block. If you PM me your email address I'll send you a photo of the one on the 350 in my '32 Ford roadster street rod. A lot of street rod builders are into bling and throw away the OEM tabs. I'm sure you can find one for the cost of postage. If I had an extra one I'd send it to you. It's not as though they wear out.
If you get on the Chevy Talk forum it's pretty likely someone would have one for you.
Ray
