2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
#125745 04/24/2007 3:37 AM
Junior Member
Junior Member
My 10 year old son and I are in the process of bodywork on our 69 GMC 1 ton dually. We have removed the rocker panels and want to clean up the inner panels and was wondering if after getting them cleaned if we should brush on some POR? It may be a while before we are ready to put the new rockers on and was wondering if you can weld to the POR? Also there are many suppliers that have rockers for this year of truck, most seem to be in the high teens for price. Is there a difference in quality between suppliers? Thanks
#125746 04/24/2007 4:54 AM
You can not weld over POR-15. The surface will have to be cleaned of all coatings, down to bare metal, in order to achieve a good, full-penetration weld. Good luck with your project.
Tony
#125747 04/24/2007 5:38 PM
Some suppliers sell "weld through primer". Eastwood has a couple different versions. For long term protection, I'd use the high zinc one.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
#125748 04/24/2007 6:11 PM
That's what I'd do... but when it comes time to weld you'll just have to sand/grind off the POR-15. It will also burn off as you weld. Then just re-apply over the top of the weld.
POR-15 on every body surface that doesn't get paint is a good rule of thumb.
Lee
1965 Chevy C-10 Gallery page
My Chevy truck pages more info and pictures!
1961 Studebaker Hawk
1962 Shasta 16' AirFlyte Travel Trailer
1941 Case Model S tractor
