0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 5 Junior Member | | Junior Member Joined: Apr 2007 Posts: 5 | My 10 year old son and I are in the process of bodywork on our 69 GMC 1 ton dually. We have removed the rocker panels and want to clean up the inner panels and was wondering if after getting them cleaned if we should brush on some POR? It may be a while before we are ready to put the new rockers on and was wondering if you can weld to the POR? Also there are many suppliers that have rockers for this year of truck, most seem to be in the high teens for price. Is there a difference in quality between suppliers? Thanks | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | You can not weld over POR-15. The surface will have to be cleaned of all coatings, down to bare metal, in order to achieve a good, full-penetration weld. Good luck with your project.
Tony | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Some suppliers sell "weld through primer". Eastwood has a couple different versions. For long term protection, I'd use the high zinc one.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Oct 2006 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 128 | That's what I'd do... but when it comes time to weld you'll just have to sand/grind off the POR-15. It will also burn off as you weld. Then just re-apply over the top of the weld.
POR-15 on every body surface that doesn't get paint is a good rule of thumb.
Lee | | |
