1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1256633 02/27/2018 2:23 PM
My 58 1/2 ton is having headlight issue. When ( new) headlight switch is on tail lights work but headlights don't when on dim.... When on bright all 4 lights dim and bright come on. Should I change dimmer switch next ? By the way the gauge cluster light and dome light both quit working at same time as headlight issue was noticed correlation? Thanks guys.
The 1958 TRI-FECTA
Stepside, Fleetside and Cameo
More Fleetside pix
More Cameo pix
More Apache Stepside pix
Check your grounds.
Another quality post.
Real Trucks Rattle
high beam is supposed to light all 4 bulbs
Insomniac
Insomniac
Before you replace the dimmer switch, make sure it's wired properly. Accidentally swapping the high beam lead and the lead from the switch could cause the symptoms you describe. The center terminal on the dimmer switch should connect to the light switch.
I suspect the new light switch is not wired properly.
When you switch on the dome light by rotating the knob, it completes the circuit by connecting to ground. If the panel (gauge cluster) lights are connected to this terminal, they won't come on! They need to be connected to the terminal connected to the rheostat. My guess is that the wires for the dome light and the panel lights are swapped on the switch.
Do you a VOM? It helps for checking these things out.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thanks guys. What I found was the problem was road grime in the dimmer switch connecting wire. Clean up contacts and all worked great. Lol it's usually something simple right?
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
Insomniac
Insomniac
What about the dome and panel lights?
Gord 🇨🇦
