7 members (Mike in Sycamore, Leo, Gdads51, 1955 1 Series, Bill Trotter, cmayna, ShopRag),
109
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Been thinking about once my current restoration is done, using some of my accumulated extra parts to build a little rat rod. I like the style that is in the picture at the link below. I've got the cab and doors, and can hunt down a nice 350 motor/tranny that will work. I guess my question is what would be the most straightforward way to build a frame. thought about using an s10 frame to build it from. I know they match up pretty easily for width and cab. This project is a long way out, but was just thinking about getting a few opinions on what would be the easiest way to go about putting one together from a frame and suspension setup standpoint. https://www.facebook.com/CustomClas...5001/515465858636097/?type=3&theater
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | A lot less work to use the S10. Adapter kits available for the engine swap. Fabrication is pretty straight forward .
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | If you want fenderless, I wouldn't recommend an S-10 frame. They look lousy fenderless, and the adapter kits for mounting the engine most likely won't put the engine where you want it.
What I've seen some guys do is build a test frame from wood to check the dimensions, ride height, etc. Once they do that they build the real frame from tubing.
If you want something like that picture I would start from a 30's-40's frame or from scratch using tubing. Anything modern won't look right fenderless. | | | | | Joined: Dec 2006 Posts: 321 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 321 | Here is one I attempted back in t 2009 / 2010... I used all vintage Chevy parts too...250 cu in 6 cylinder. 4 speed out of a 1970's truck...Chevy Camaro rear end... yea old rat rod Good luck with your project... MikeC 1951 Chevy 3800 1-TonHoward KnappIn the Stovebolt Gallery1948 Chevy 1-Ton (sold Nov 2017)1953 Chevy 1-Ton (sold 10/1/2016) | | | | | Joined: Jul 2015 Posts: 10 New Guy | | New Guy Joined: Jul 2015 Posts: 10 | I used a Chassis Engineering front end, X member and brakes. 350 SBC and a 4 spd Saginaw....the hot set up for not a lot of cash...and it bolts right in. | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Looks like a fun project Jon. Get it figured out and start a journal so we can ride your coat tails.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | If you want fenderless, I wouldn't recommend an S-10 frame. They look lousy fenderless. Anything modern won't look right. I have to agree,they really need a beam axle and ideally split 'bones to carry off the fenderless look. S-10 chassis' while popular,relatively cheap and commonly available (at least on your side of the pond) sure aren't purty! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I have to agree,they really need a beam axle and ideally split 'bones to carry off the fenderless look.
S-10 chassis' while popular,relatively cheap and commonly available (at least on your side of the pond) sure aren't purty! Yeah, they're great when they're hidden under the sheetmetal, I love mine, But for fenderless... just no. The I-beam with split 'bones is my preference as well. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Was looking back through some old posts. I'm going to shelve the idea for now. Too much effort and too little margin. I think I'll just craigslist my spare parts once my beast is done. Would be fun, but one more thing to park, keep running, and knock dust off of. Honestly looking at a mid 2000s Tahoe or Suburban 4x4 to convert into a fishing/camping/hunting rig. Thinking that I will sell my CJ7 and buy the tahoe. I'll use it way more than a hot rod. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Split wishbones and cross springs are strictly a Ford design, but they make a frame lightweight and easy to build. Doing a ladder style frame with rectangular tubing and cross springs and then channeling a stovebolt cab over it would look a little "Rube Goldberg", but it would be fairly easy to build. Jerry
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I have seen many ratrodded fenderless ADs and have yet to see one that looked right. Its all about the area of where the fenders used to meet the side cowls of the cab. It just doesn't work.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I have seen many ratrodded fenderless ADs and have yet to see one that looked right. Its all about the area of where the fenders used to meet the side cowls of the cab. It just doesn't work. If you filled in the cowl area and smoother out the firewall to where it met the cowl, it would help. The other issue is the cab is so darn big. Chop the top and then narrow the cab up. A big block with Zoomies, yeah that would do. | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | I've had a similar project bouncing around my head for several years due to the massive amount of modification needed I decided to build it as a model. Stock frame from a 54 (I have a junk one) Z'ed and shortened. Motor would be a Buick Straight 8 (Also have the motor) 10 inches Sectioned out of the middle of the cab. Square off firewall and cowl (Like a roadster should be). I didn't do it on the model but most likely section some height out of the cab as well, or potentially raise the floor to get the body further over the frame and closer to the ground. Shortened bed.. Never figured for sure what the scale measurement would be but it needs to balance out the massive Buick 8 on the front. Ahh, also I've collected a 4 inch drop axle for the front and planned on running 16 inch wheels all the way around. Mongo's Garage AD Roadster Hot RodSome time back I decided I was going to own every body style of AD trucks there were... Then I decided I needed a few that didn't exist.. Mongo | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Ahh to clarify on the frame I planned on using the 54 3/4 Ton frame for a couple different reasons the rear axle kick up is lower so the bed can sit 2 inches lower on the frame and the frame rails are parallel from the cab back as opposed to tapering all the way back as on the 1/2 ton. This should make Zing the frame a little easier. Also the 3/4 ton frame is heavier to accommodate the Buick motor and all the modification..
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Buick drivetrain... I like what you're thinking Mongo. | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | So I went to deliver some parts to a body shop this week and they asked me if I wanted a cab they got back from getting blasted that was way too far gone for them to use for their customer otherwise they were going to send it to the scrapper. I took a look and although it was really really bad, It had an unmolested radio hole and the cowl vent didn't look too bad so I figured I could cut those out to put on the shelf when a customer needed to fix either of those spots. So being bare metal I didn't want to leave it outside so I've been working around it in the shop all week. Saturday afternoon I got a few minutes and fired up the plasma cutter to trim out the patch pieces. Then I decided that the cab would be perfect to mock up the roadster project full size. So I went ahead and cut the firewall/toeboard and the top off and sectioned the center out of the cab. For now I screwed it together with a couple scraps since my welder is at my other shop right now. I did the obligatory milk crate drive to test the fit and I'm liking it. The milk crate is a little tall, but I've got an S-10 bench that should fit nice and set a little lower. If I end up sticking with this cab for the project it's going to need a lot of work but it's a pretty seriously modified project to begin with. The floor is pretty toast so I'm thinking a whole new one piece Floor/Toe/Firewall and in the process of that I might raise the floor a couple inches more to further hide the frame under the cab. Anyway It's going to get rolled in the corner of my other shop for now but when I get some more time I'll pull it out and tinker some more with it. And I added some pics to the gallery I shared before above and HEREWorse case I saved some pieces that will help some other guys. Keep on Truckin' Guys.. MONGO | | | | | Joined: Aug 2003 Posts: 106 Shop Shark | | Shop Shark Joined: Aug 2003 Posts: 106 | That's great! Looks too fun as a roadster.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert 55.1 GMC 450 COE 51ish GMC Suburban | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Looking good so far, Mongo. Good plan on not making the full sized one out of soap.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Mongo, no one ever accused you of thinking out of the box! Use it up, or wear it out. Do with or do without...................your my hero, Steve! | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | That looks really cool Mongo! | | |
