| | | Forums66 Topics128,010 Posts1,055,298 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 18 'Bolter | | 'Bolter Joined: Apr 2013 Posts: 18 | I have a 1934 Chev ! 1/2 ton truck i just recently rebuilt the engine and replaced the radiator core the trouble is when i started the engine up the water was coming out of the top of the radiator by over an inch high with no cap on the radiator and when the cap was on was still coming out between the cap and the radiator any suggestions on why and what to do to fix this problem
1934 1-1/2 ton truck (Australia)
| | | | | Joined: Feb 2007 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 112 | Something is blocked. Better check the rad. again. I would remove the lower hose and fill the radiator with water engine not running. The water should run out the lower neck of the Rad. almost fast as you pour it in. Almost the key word here. If it has good flow then look at the engine block/head for something abnormal. You can flush engine block in much same way looking for a restriction. Tom | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Could be air trapped in system. Google "Burping" a motor. Park up hill. Could be over heating. Watch the gauge. Could be too much fluid in Rad. Could be water pump running backwards.....wrong water pump Could be a screwed up "new" core install
Please always state what motor, as well as year and model.
Is there steam? Bubbles? Thermostat correct/new? Overflow tank installed? I have read that heater hoses on backwards can cause bubbles. I don't know if that's true.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
