| | | Forums66 Topics128,107 Posts1,056,221 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 53 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 53 | Hello all, I measured my pitman arm ball at .985" and then perpendicular at .957" with an out of round difference at .028". I am wondering if this will affect steering and should I put on a replacement ball? I am assuming originally they were 1" round.
Thanks, Jerry | | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | Yes, it can make the steering act funny. You will have to overcome the spring pressure on the balls every time you turn. With a round ball, the spring pressure will be constant. If you do replace the ball and sockets, chuck the ball end in a drill, while spinning in the drill, apply lapping compound to the cups and lap them to the ball. It really helped mine. | | |
