4 members (TooMany2count, frogfarmer, moparguy, 1 invisible), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
#125008 03/12/2007 3:31 AM
The large panel (below the rear window), on my '48 AD is really beat up. I have a donor cab with a good rear panel. My question is, is it best to try and drill out all the spot welds on the good panel or... just cut out whats needed to replace the damaged area?
#125009 03/13/2007 4:41 PM
I didn't have to do anything to that area on my truck. But my opinion...thats a perty flat area and depending how large of an area needs repaired, cutting out the area that needs replaced would be easier then drilling out all those spot welds. There's other people in here who may have better insight with this. Hoped this helped.
~Ron
#125010 05/11/2007 3:55 AM
Has anybody else done this? I have the same problem. I plan to buy the new rear cab wall. The assembly manual makes it look like you would have to take the entire upper inner metal out. The part joined around the window frames. THe lower cab back is overlapped pretty good with all the upper pieces. Any thoughts?
#125011 05/11/2007 1:40 PM
Anonymous
Unregistered
Anonymous
Unregistered
I have performed this transplant on my 54. I drilled out all the spot welds on the sides and bottom and then cut just south of the belt line. I then welded as 1/16" thick backing strip to the inside of the remaining belt line area material and used this to weld the top seam of the panel.
I may have some pictures I can send you of the process.
