0 members (),
110
Mod | | | Forums66 Topics128,183 Posts1,057,264 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2017 Posts: 9 New Guy | | New Guy Joined: Dec 2017 Posts: 9 | was wondering if someone would know. the front hubs of the truck were the 4x4 axle goes in the hub the part that the wheel bolts to if that should be half full of oil or should it be dry | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Hi and welcome to the site! Be sure to stop by the welcome wagon forum and introduce yourself and yell us a bit about your truck!
I am not sure on front hubs that big of a truck, on all my jeeps and my Suburban (all 1/2 ton axles though) you greased everything to keep it lubed but there was no gear oil in it.
I am sure someone will come along that is familiar with your model and year of truck. | | | | | Joined: Dec 2017 Posts: 9 New Guy | | New Guy Joined: Dec 2017 Posts: 9 | the reason i thought it might need oil in the hub is it has a drain plug or filler plug in the hub | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | it very well could, I am not sure and do not want to steer you wrong! I am sure we'll hear from some of the other members in the next day or two. Happy New Year! | | | | | Joined: Feb 2007 Posts: 112 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 112 | That 2 ton model should be the KV4000 The Wheel bearings and hub cavity should be packed with wheel bearing grease.
As well as the knuckle cavity, upper/lower king pins.
If you have oil in there you have a leaking axle tube seal and it's washed the Grease out.
And Welcome.
Tom | | |
