2 members (Kilted54, UtahYork), 72 guests, and 2 robots.
Topics128,196
Posts1,057,392
Members48,469
V
V Offline
Hi all!
After much deliberation I've decided to replace my original carb and harmonic balancer. I've kept EVERYTHING original until now, but the Rochester B just leaks too dang much and has throttle issues. Cleaned it and done a rebuild kit three times now. The seals on the Harmonic have gone bad, so I guess it's time to replace it with something new. I'm too worried the wobble it's developed will ruin my engine. And I'm not buying a used one again..
The engine is an original 1957 235 Straight 6. I've seen some suggestions on which carbs to change to, but my actual issue has been finding one!
My problem is I'm not looking for a used with rebuilt kit. I'm looking for a reproduction or something new. But I still want it to have manual choke and manual throttle cable attachments.
Does anyone know a place that sells something like that? I'm 100% ok switching to Carter or another brand. Just looking for manual choke and manual throttle. Probably stay with single bbl unless you guys suggest a reason otherwise. Not looking to make her a powerhouse, I want to keep her original farmhouse feel smile
Same question on the Harmonic. I've seen a few that *SAY* they fit on Summit Racing, but can anyone vouch for the new harmonics on these trucks? Just want to check with you guys before I buy one.
Thanks for any input!
1957' Chevy Pickup
My welcome thread: Introduction and Story
My Album: 57' Chevy 3100 W/235
Look at www.thecarburatorshop.com. Get their contact info and contact Carbking for recommendations.🛠
For the balancer try these guys http://www.damperdudes.net/ .
They did a great job on mine and have an excellent reputation.
I will give Damperdudes a thumbs up also, they are a great place to purchase from, they fixed me right up.
Do not purchase an over the counter carburetor form your local parts store, you never know what you will get, and if you do, do not turn in your original unit as a core.
Crusing in the Passing Lane
I got a new balancer for a 292 for my 302, 2 belt grooves, was made by Australians, have box at home if anyone needs PN when I get home, recall had to adjust thickness.
Ed
V
V Offline
Awesome, I'll definitely check out damper dudes!
Every forum I have checked, even Jalopy and a few others mentions CarbKing. I didn't know if he was still around!
I've been to a LOT of car shows here in Orlando looking to see how most guys run their carbs, but unfortunately everyone around here seems to get rid of their original engine in the 3100s.
Finding a carb is definitely priority #1 so I'll see if I can get in contact with CarbKing, but in the meantime I'd love to hear everyones carb stories or suggestions if you have a 235!
1957' Chevy Pickup
All balancers are identical, and it doesn't matter which one you use.
Originally Posted by panic
The only exact fit harmonic damper (it's not a balancer) is BHJ: $$$.
I thought this topic was/is about finding a 235 crankshaft harmonic balancer?
GM Group Number: 0.659
balancer, crankshaft
Some might use a different name, but, no need to confuse someone who is using GM manuals/terminology.
(step 11, for another example)
damper/balancer would be an ok designation for this forum and this question and this suggestion?
Nonetheless, as you posted ($$$) $475 + $35 shipping for that new harmonic damper would have me looking for a good used harmonic balancer.
It's possible to adapt a 265/283/307 V8 balancer to a stovebolt six with a little machining. I had one I made that way at the homecoming last spring. The cost was about $125.00 with all brand new parts. It also has TWO belt grooves for adding air conditioning, power steering, etc.
V
V Offline
Oh, that might be something I'll want to look into then.
As much as I'm trying to keep it original... I'm in Florida. I drove it once without AC in July and that was enough for me. Second belt groove would be nice.
1957' Chevy Pickup
I've had GREAT success with Carolina Carb rebuilding my original 1 BBl. They have a flow bench that is great, no adjustment required after carb is rebuild. Put it on, connect gas line, tap accelerator, pull choke, motor starts. Send them your carb, same one comes back to you rebuilt.
http://www.mycarburetordoctor.com/
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
Ex Hall Monitor
Ex Hall Monitor
Enough of the nonsense! It's OK to disagree but not OK to do it in this way. This thread is locked until the site owners get a chance to decide what to do.
24601
24601
Decision made. Action taken. Thread unlocked.
Carry on.
Be nice. It's Christmas, dammit! chug shake
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Try vintage speed, Charly Price. He did me well. vintagespeed.com has a lot of different stuff.
