| | | Forums66 Topics128,007 Posts1,055,281 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | I would like to repaint the posts that run between the window and the wind wing on the doors of my 58 stovebolt. What is the best way to achieve a glossy finish? Is this some type of clear coat or is there a high gloss black paint that provides the same look as original or is a matter of technique? Sorry if this is a simple question, but I already tried a semigloss black lacquer that looks flat in comparison to the original color. About all I can say about that attempt is the surface rust is gone and the metal is protected.
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "semigloss" is the problem, need to use a normal gloss black, and skip the laquer, surface rust is just covered up and metal isn't protected at all - it won't hold up long, use some type of enamel ... good quality rattle cans work
Bill | | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | Thanks, I'll get some plain gloss black enamel Rustoleum. I did prep the surface and used a black Rustoleum primer.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | |
