Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (TooMany2count), 49 guests, and 1 robot.
Topics128,009
Posts1,055,291
Members48,419
#124723 02/27/2007 2:15 AM
I would like to repaint the posts that run between the window and the wind wing on the doors of my 58 stovebolt. What is the best way to achieve a glossy finish? Is this some type of clear coat or is there a high gloss black paint that provides the same look as original or is a matter of technique? Sorry if this is a simple question, but I already tried a semigloss black lacquer that looks flat in comparison to the original color. About all I can say about that attempt is the surface rust is gone and the metal is protected.
58 Fleetside, 235, "The Old Buckin' Bronco"
#124724 02/27/2007 2:36 AM
"semigloss" is the problem, need to use a normal gloss black, and skip the laquer, surface rust is just covered up and metal isn't protected at all - it won't hold up long, use some type of enamel ... good quality rattle cans work
#124725 02/27/2007 7:06 AM
Thanks, I'll get some plain gloss black enamel Rustoleum. I did prep the surface and used a black Rustoleum primer.
#124726 02/27/2007 7:17 AM
exactly the ticket
