| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 33 | OK, probably another dumb question, does epoxy primer come in colors (blue, black,green,etc.)? Im wanting to get that original "old farm truck" feel and i was thinking about just putting a color primer (hunter green) as original. Your input would be appreciated.
- Zach Morris
| | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | I think the uv rays from the sun will eventually break down the primer. I'm pretty sure it needs to be top coated for long term use.
1970 C50 dump! saving orphans from the CRUSHER
| | | | | Joined: Jan 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 33 | OK, Thanks rustmaster, you've been very helpful!
- Zach Morris
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Are you planning on painting the whole truck this primer green or are you going for the patina look where some orginial base color is left plus in some areas the primer is showing? Anyway you should be able to find what color you need at you auto paint store.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Hey, SCboy, you are in my neck of the woods. Just 20 miles/minutes up the road. Ever come to the Beacon Cruise In's in Spartanburg?? The club I belong to does cruise in's there every 3rd Friday of the month starting in March. Come see me. Just ask for the guy with the "obinoxious pickup" and they will point you in my direction.  | | | | | Joined: Jan 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 33 | Never been to that cruise in, but know exactly Where you are Achipmunk,eaten at that Beacon a few times. Im want the whole truck that color. Have ya'll ever seen the old navy blue Chevy truck that sits in usually every Old Navy clothing store surrounded by clothes? I know that sounds weirds, but thats what im talking about Beltfed. Thanks a bunch!
- Zach Morris
| | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | couldn't you just paint it with rustoleum enamel. I sprayed stuff years ago. I bought it in qts or gallons and sprayed it in a gun. gives it that look you are going for and it's cheap. Or if you wanted to go the high end route you could use a base/clear coat system with a gloss reducer in the clear. Try some rustoleum on a test pice and see if thats what you are looking for.
| | | | | Joined: Jan 2007 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 33 | Man, now your talking my language (cheap) thanks for the advise rustmaster, im ready to go shopping now!
- Zach Morris
| | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Btw, if you fool around with the gun pressure it will change the texture and give it a flatter look when it dryes.
| | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | you can also use tractor paint some of these guys swear by it
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Nov 2006 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 84 | Epoxy long term test: I have been spraying DPLF epoxy primer for a few years now. You can get it in five or six different colors. It cures out to a beautiful even satin sheen and bonds like crazy I have been tempted to not paint over it. Anyway I did an experiment. I sprayed the black primer and the white primer on a piece of aluminum and let it sit outside for the past 16 months. The white primer yellowed some and the black primer faded a little. Both of the colors were still bonded to the aluminum great but with one wipe of a wet towel the top surface smeared off. As rust master stated the UV from the sun eventually breaks down the epoxy primer. | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | I have heard of guys using industrial paint (tractor paint) I believe it is a enamel like the rustoleum. may be a little srtonger.construction companies still ues industrial enamel to paint big trucks
