| | | Forums66 Topics128,108 Posts1,056,558 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2017 Posts: 30 | Hi everyone, it's been a while since my last post, and I'm glad to be back.
Anyways, in my last post I asked what my next step should be on my 62 C10. I have the engine out (planning on swapping in a small block) and I asked what others thought I should work on while I sort out getting a new engine. It was suggested that I work on the brakes and just replace the brake lines and work on the drums, but I'm not totally confident that I know everything that will need to be repaired/replaced. I know the brake lines are all shot, but I'm not sure what the actually components inside the drums look like. I won't get to work on the truck until I get off school for Thanksgiving break, which is in a little over a week.
I was wondering if there are any good guides on how to restore drum brakes on old Chevy trucks, or if anyone has any tips on how I should go about working on them and identifying what needs to be replaced.
Thanks!
College student trying to restore grandad's 62 C10
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Matt, when working on brakes work on one wheel at a time so that you have a reference on the other side to look at. The 62 will be pretty straight forward. The drums should have a number stamped into the drum showing the minimum size/wear it can have. If not worn to much it can be turned at a brake or machine shop. That will true up the drums. Around here I get drums turned/trued for 5 bucks at my favorite place but most charge 8.50 here in my home town for drums.
Do you have a shop repair manual. If not it'd help you to get one from one of the vendors listed in the LInks section.
| | | | | Joined: Jun 2017 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2017 Posts: 30 | Thanks for the reply, I don't have the shop manual yet, I meant to purchase the 1960 shop manual but purchased the 1962 supplement manual by mistake. I plan on purchasing the shop manual when I purchase the replacement brake lines. I assume that I'll also have to replace all the springs and other internals in the brakes as well as the wheel cylinders, but someone please correct me if I'm wrong. I want to be able to purchase the majority of the parts I'll need at one time for convenience and to save money on shipping. If anyone is wondering about the condition of my truck, it's been sitting for 25+ years on the side of my grandfather's shop. Here's a photo from a while back: My Truck
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Matt, I do not think all the springs and things on your truck will be bad as they have been covered for the most part. However, I do know you can buy the "kit" with all the springs and things in it. I would think for about 7 bucks a wheel if you get a discount somewhere. They fit a lot of years......you can check them out from the vendors but I'm sure you can get them from you local guys....cheaper and no shipping. I purchased some from Advance Auto just a short time ago for a 59. Probably the same thing fits yours? Congrats on your truck and remember, we are all her to help. Its a journey we can help you with.
EDIT: you will also find a forum here for the 60-66 model year. We have a couple guys that are sharp on this style. Be sure to check out Jay's "lugnutz" build on his truck.
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Rockauto.com will have 99% of everything you could need for a total rebuild. Their online catalog is very easy to use. Shipping is quick and they do have a fairly good return policy if needed. Your drums will be 11X2 and are readily available if needed. As Alvin said these parts were used for many years and are not rare.ðŸ›
| | | | | Joined: Jun 2017 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2017 Posts: 30 | Thanks to both of you guys, I appreciate the help. I'll hold of on getting any parts besides the brake lines until I get a good chance to look at the brakes and see what needs to be replaced.
Thanks again for the replies!
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Inline tube has all of your brake lines in stock, individually or as a set. The hyd clutch line should be updated as well while you are there. All is doable with engine out. The hardest to get at is the line that runs across the frame under the trans mount. You should have easy access to the lines. All brake kits and cylinders are at napa or other local retailer. You may have trouble getting the drums off. Youtube shadetree methods. It might take time and patience so plan that in. (Start the drum removal as soon as you get home.)
