| | | Forums66 Topics128,080 Posts1,056,062 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2017 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2017 Posts: 42 | Back in 1971 I briefly had a 1954 3100 truck in running & driving condition. The truck was painted a bright metallic blue and had been upholstered in white naugahyde. It also had an after market air conditioner. It had been owned our local scout master and I spent many happy hours riding in the cab or even in the bed enroute to camping trips when I was a kid. I ended up loosing the truck due to reasons not too rare to a kid just out of high school. I needed the money and it had to go.
The truck was gone but I never forgot it and started looking for another one. As I became more familiar with them I found I actually preferred the earlier models with the slat grill. I walked past one parked on a neighbor's property every afternoon and one day it had a FOR SALE sign. I called and arranged to go look at it. It was a 1951 3600 model without the little quarter windows, a feature I much admired. The truck was one of those "ran when parked" jobs but didn't look too bad. It was complete and did not have any rust I could see. It had a camper on it. We agreed on a price & a pal towed it home behind his big dually diesel.
He wanted the camper and I was happy to let him have it. When we jacked the camper up it literally fell apart. It had been eaten by termites right around the top of the bed railing. No matter, off it came and my pal got a couple of years of use out of it before he retired it to scrap.
The termites had also eaten into the bed wood and I put a foot right through it while washing & polishing the paint. It will need a new bed sometime down the road. Until then it will just get a sheet of plywood.
My plan was to do a bit of fixing up and just drive it as it was. I did the gas tank ReNew, overhauled the carb & installed new points, plugs, cap & rotor. A compression test showed huge variations and it was going to need a valve job but it did fire & run with a HUGE racket. After listening to the motor with a stethoscope. I thought the problem was a bad timing gear. That and the bad compression had me looking for a used 235 which I found with a fellow who had just taken it out of his AD truck which was to receive a V8. I did briefly drive the truck, just up & down the alley in first gear. The only brakes were the hand brake and it didn't seem wise to push things.
I was working on the truck hammer & tong until a motor became available in Canada for a long delayed 1926 Hudson project. That was ten years ago and the old Chevy just sat patiently waited for me while I turned my attention to other long neglected projects including a 1923 Model T Runabout and several motorcycles. Last summer I even determined to sell it still as a project. I need to thin the herd and had just sold an MGA that I never got around to so the truck looked like it was destined for a new home.
A pal suggested getting it running and then either keeping it or selling it. That made sense and I started in by trying to figure out where I left off a decade ago. What parts were bought? What more was needed to get it running? Somewhere in the process I fell in love with the project again and have decided to keep it.
Now I'm working on a complete rewire & 12v conversion. Some previous owner had done some "hippy" wiring with things like TV antenna wire and miles of spaghetti like blue tail light wire. That's were we are right now. I have a conversion harness bought ten years ago from Jim carter, he EL 170C. It came with a single sheet listing of wires, incomplete and riddled with errors. There was NO wiring diagram!!!
The alternator is not even mentioned even though it has a separate 3 wire harness for it. Where do the wires go? I know it must be simple, but I'm electrically simple too . . .
Vintage Paul Paul O'Neil, SoCal 1951 Chevy 3600 Project
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Paul, a few minutes EVERY day will accomplish much in a few weeks time. Just be persistent and patient. Sounds like you could have a daily driver with in reason both money wise and work wise. We welcome you to the stovebotl and rest assured that folks like Tim, and many others here will help you along the way as you need help. Remember, Knowledge is the Best Resource. | | | | | Joined: Oct 2017 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2017 Posts: 42 | Thanks Tim, it is a 3 wire Remy 42 amp alternator. The separate harness has three wires, two from a plastic clip, one large Red one that seems to go on the stud sticking out of the back of the alter. to a battery connection someplace. I have read generic instructions saying that one of the two wires in the plastic clip goes to a GEN or IGN light then to the switch. The other goes directly to switched power. This 1951 truck has no lights like that. Do I need to add one to make this work?
| | | | | Joined: Oct 2017 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2017 Posts: 42 | Thanks for the welcome Achipmonk. I've had this old AD for a dozen years and the last ten of those it has lain dormant. Now its time to push it through to completion. It will be very handy for an eventual move.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Welcome, Paul! Your electrical questions are probably best asked over in the electrical forum. I do know that when adding an alternator to an old tractor that one of those wires is sometimes run to a generator light of some kind. Another option is to put a diode in the circuit. If you don't do that the thing will keep running even after you turn the switch off. That's about the extent of my electrical knowledge! As mentioned, ask the guys in that other forum for a better explanation. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "3 wire Remy 42 amp alternator" If you can find a part number, you might be able to find wiring/connection information with an Internet search. And/Or, post the part number here. http://www.madelectrical.com/electricaltech/delcoremy.shtml | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | welcome to the site! Good job getting back to it! As suggested, maybe post a pic of your alternator along with the question in the electrical forum! | | | | | Joined: Oct 2017 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2017 Posts: 42 | Thanks for the warm welcome from all. The alternator is a Remy 20040 which has three wires. I'll zing over to the electrical forum as I have other Qs too about things like removable waterproof connectors.
On a completely separate matter I thought I would mention a very unlikely sounding "attraction" for me with these old Chevy Trucks. When I was a kid I could tell the Chevys from other trucks by a sound that was made when the driver eased off the brake or clutch pedal and the pedal driven by the return spring whacked a rubber bumper into the floor boards. It was so distinctive I could tell the Chevys even with my back turned. I always liked that sound and hope to be making some of my own here in the next few months.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I remember that sound too! The one I have now doesn't do that. Or if it does I'm so used to it that I don't hear it anymore. | | |
