2 members (Gray_Ghost, 1 invisible),
179
Mod | | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | Not sure if this should be in engines or general, so I'll start here.
My radiator ('53 3600) will be about $325 to fix up new according to a shop I trust.
I know in a catalog I saw, that that's not too far off from a new one. This is the original radiator, and I'm putting a '56-'57 235 in the truck.
Is there a specific advantage to using the original (other than to keep it original) or would a new one be even better? With the cost I'm not sure if one's especially better than the other. Ideas?
'53 Chevy 3604 Five Window Cab ('56 235)
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | I ran an original recored radiator for years in my '37. After about a year or two I saw antifreeze around the top tank. I had it repaired and went for a year or so again and same thing happened. I soldered it this time. After the third time taking it out, I replaced it with a new aluminum. This solved all the leaking and let me run a much higher PSI cap. The original radiator top tank was made from brass which was very thin. Every time I drove the truck I would head the tank "pop" when it was heating up for the first time The pop was the tank expanding from heating coolant and the solder joints just couldn't handle it. I had as much money in the new core and repairs as I did in the purchase of the new radiator. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Have to make sure to only use the original PSI rated pressure cap on old radiator, 4 or 7 psi.
Ed
| | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | Have the heater core replaced with a higher pressure rated one, run the modern radiator, and you'll be able to run a pressure cap in the 14-17 PSI range without a problem. That will eliminate any coolant loss whatsoever, particularly if you also run a small recovery tank. A 15 lb. cap raises the boiling point of the coolant to 257 degrees, far higher than a stovebolt engine ever gets during normal running. The water jacket and cylinder head handles the pressure easily- - - -the heater core is the limiting factor. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I had the original in my 51 re-cored. They told me that it wouldn't look exactly the same but would provide more cooling than the original core. they were right. I am very happy with it. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bought an original from JCarter several years ago (desert cooler)? and I have ran it with a 305 in my panel for several years and with a high pressure cap. It may bite me in the butt one day but so far so good.....and that included it running hot one night when I had forgotten to tighten up the ground wire on the electric fan after some adjustments. Everyone's results may not be the same as mine! | | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | Well, I decided to go with a new radiator, found a new one for a couple hundred (if that), so my cousin calls the shop since he's going to be around there to tell them he's going to stop and pick up my old radiator. Turns out they already started working on it! Long story short, they agreed it was their fault and said they'd do it for $250 (and described how well they'd do it and how it would take more pressure and they'd guarantee it, etc...). So I'm going with the old one.
