8 members (mvigo, Charles in CA, Rusted Nut, UtahYork, Peggy M, Shade Baby, klhansen, 1 invisible), 80 guests, and 2 robots.
Topics128,074
Posts1,055,913
Members48,429
#1238993 10/12/2017 10:45 PM
Hi all, well I have been talking to the son of the original owner off my truck after it was sold post WW11 and he has said that the truck was rated as a 6 ton truck.
I have the original service manual and it only rates the truck at 1 1/2 ton ????
Some specifics on my truck: 1942 1 1/2 ton ???
: 216 cc and 4 speed box
: 160" wheel base
: single axel
:single speed diff with duel wheels
: The flat bed is 12 ft with 10 boards across
Quick note is that the truck is part of the blackout series that was built in Detroit as a R/H drive (sent to Australia) to help with war effort in 1942
I would just like to make sure i have all my info correct
Hope you can help
Cheers Justin
Aus42blackout #1238998 10/13/2017 12:13 AM
12,000 load weight, or GVW?
Crusing in the Passing Lane
20 inch tires?
Ed
Aus42blackout #1239032 10/13/2017 10:17 AM
TGP Offline
I don't see how that can be a 6 ton truck.
Ton and a half truck empty weight of approx.. 7500/8000 lbs.
Depending on the bed.
Maybe a GVW of 12,/13000 lbs. JMO
Tom
yes 20" tires
thanks guys I think I will just stay with the 1 1/2 ton load rating because of what I know about truck ,and there is not a lot off info about the blackout trucks in Australia to verify numbers
cheers
If it is a Canadian built, and imported truck, it could actually be rated a little higher than a GM U.S. built truck, of the same size. I've noticed by collecting GM truck literature through the years, the Canadian built trucks, are rated higher/gvw, and Military trucks lower/gvw. I(s it a Chevrolet, or GMC ?
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Aus42blackout #1239264 10/14/2017 11:12 PM
My 52 Canadian Chevrolet 1700 is rated at GVW of 17600 lbs, but is considered a 3 ton. What model is yours? As Spanky said above the Canadian built models had different ratings.
1952 Chevrolet 1700 Bickle Seagrave
"Old Smokey'"
Following the build in the DITY Gallery
My is a USA built chevy, frame number is 42 D 4409-4(R or B) 739, model number is 4409 and the contract numbers from war are W-398-QM-12981 and W-398-QM-13006. I am not sure if the contract numbers help ID truck size ?????
Cheers Justin
Some Canadian Chevy trucks were called maple leafs. Some of that era
were 2.5 and 3 ton.
There were a few long WB 160" 1.5 trucks made in the Art Deco years.
VIN number should reveal what model truck you have. Jeffrey
Aus42blackout #1239543 10/16/2017 10:51 PM
Big Bolt Forum Moderator
newer trucks, 4409 would be a 4400 model, or a 1.5 ton.
Mike
