9 members (FishinToms53, Otto Skorzeny, Gray_Ghost, Wally / Montana, TooMany2count, 1955 1 Series, baldeagle, KEVINSKI, 1 invisible),
90
0
Mod | | | Forums66 Topics128,052 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Hey Bolters, I need some assistance identifying this Trans Cover. I bought it some years ago from a fellow Bolter for my '59 when I opted to install an SM-420 Transmission. It fit onto the floor but didn't match up to the gear shift location. Also, the gas pedal holes were cross ways and it doesn't have a hump. It's like the flat type for a column shift light duty truck. I suspect it came from a big bolt truck but not sure what. Can anyone help please? I'm putting it up for sale and just need to identify it. See pics. Thank you. Pic-1Pic-2Jerry
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 |
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well, it IS a 5-9 cover for a column shift, but with the hand brake slot it would be a 1T and up, shift hole could be for a "PowerMatic" if it doesn't match a 420
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Thanks Bill, I'm not at all familiar with the "PowerMatic". Is it an automatic transmission for a big truck? If so, the flat cover versus hump style would be correct for it? Jerry | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, 6 speed automatic for 2T, just a thought because of the different shifter hole paired with the driveshaft brake
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Guys sorry I'm late getting back to your replies. Tim, I bought the cover for my '59 truck when I switched over from 3'sp column with an SM-318 to a 4 speed on the floor. The seller couldn't tell me what it came out of and I bought it from the pictures, based on the shifter hole and E-Brake slot since I have an E-Brake on the SM-420. I acquired some learning from that. First, that a humped version of the cover was required for my SM-420! I just need to get this cover out of my garage and wanted to identify it properly.
I'd love to see a pic of this type of cover used with the "Powermatic" and E-Brake in a big bolt. Does anyone have one they could share?
Thanks again! Jerry | | |
