3 members (Hotrod Lincoln, Chip O, Steelonsteel), 125 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
I'm wondering if anybody knows where the small copper tube coming from the heater valve on a deluxe fresh air heater mounted up under the dash?
Look in the chevrolet Factory accessories manual , it'll tell you exactly where to mount it.
1951 Chevy Accessories Installation Manual
Tim
1951 3100 Chevrolet
Dr. J,
Good luck figuring out the location from this instruction's illustration.
Mine is attached to the floor mat on the middle toe-board area, on the right side of the "hump".
I made a block out of 1/8" thick material 2 5/8" x 2 1/2" used it as a guide.You can use cardboard, heavy paper whatever it takes.
The picture gives you all the measurements in relation to the heater valve.
Tim
1951 3100 Chevrolet
Here is another view--from my '48 Chevy 1/2 ton:
http://s160.photobucket.com/user/st...anovsky/IMG_2106.jpg.html?sort=3&o=0
Be careful handling the unit--they are easily damaged!
