| | | Forums66 Topics128,214 Posts1,057,488 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 4 New Guy | | New Guy Joined: Aug 2015 Posts: 4 | I'm wondering if anybody knows where the small copper tube coming from the heater valve on a deluxe fresh air heater mounted up under the dash? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Look in the chevrolet Factory accessories manual , it'll tell you exactly where to mount it. 1951 Chevy Accessories Installation ManualTim
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Dr. J, Good luck figuring out the location from this instruction's illustration. Mine is attached to the floor mat on the middle toe-board area, on the right side of the "hump". | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I made a block out of 1/8" thick material 2 5/8" x 2 1/2" used it as a guide.You can use cardboard, heavy paper whatever it takes. The picture gives you all the measurements in relation to the heater valve.
Tim
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | |
