1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | Does anybody know how it would turn out to sand the frame, then brush on the black frame paint? I don't know if it would leave brush marks and I don't want to take it to a body shop just for the frame to be painted. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | It should turn out just fine...a lot of people do it like that. I brushed POR 15 on my '52 frame and it came out pretty good...seems to be self leveling. Just don't put it on too thick. Lots of other good products out there as well. Do some searches on this site. Lots of information on this. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | A lot of the frame paints are self-leveling and look good brushed. Remember to never spray POR-15 without a positive pressure respirator. I used POR on the last frame I did (a jeep) and it looked fantastic. In fact, if you add some Xylene to it, it actually levels better and comes out glossy.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Instead of a brush, what about a small roller? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Just my 2 cents ....I been doin mine with Eastwoods X-Treme Chassis Black ...Satin ...so far so good ..Rattle can | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Zero rust goes on smooth with a brush. Thin it out a little. A foam weenie roller would be good but you will need to cut in the tight areas with a brush first and roll over it before it starts to dry | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | POR-15 needs all kinds of precautions. Zero rust worked great for me with a brush, roller, paint gun, or aerosol can in any weather. It has a satin finish which I like on a driver. I brushed my inner fenders with zero rust and then clearcoated which turned out great. If you want the whole frame shiny then go with POR-15 or Endura.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | This is what the results looked like on my '66 Chevy C20 front frame rails. I used Industrial Purple degreaser, a good scrub brush and some elbow grease in preparation before applying POR-15. I did all of this with a quarter of a pint of black POR-15 with a small detail brush in a few hours. I used the small detail brush, in order to get in the tight spot, as encountered with front suspension parts. I am very happy with the results, both appearance, durability and lasting protection. Frame Rails Before POR-15 Frame Rails After Degreasing & POR-15 | | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | i used rustoleum hammered black and its turned out great id really recommend it if you want durability, but some people dont like the hammered finish. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i wire brushed (6 & 8"" electric wheel brush as well as a hand brush) my frame before and after a couple times at the high pressure car wash/degreaser wash/ rinse. I preped the frame, then brushed on gloss black POR 15
it looks great!!!!! and as far as I'm concerned if it lasts 20 years i probably won't be alive to care.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | I had my frame sandblasted.. then it was sprayed with epoxy... afterwards, I sprayed it with tractor paint... but yes, you can brush it on if you want.. I've seen a lot of cars like that and they turned out really nice. Go for it!
1952 Chevy 5 Window Restoration
