| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | ok im building a paint booth for heat i have a real nice forced air fernice it even has a air cleaner im going to run it to get the booth warm shut it down paint then crank it up to 90 to set the paint should i instal it in the booth or set it outside in the other room and run ducting if i put it in the other room it would be using cold air to heat instead of the warm air in the booth need advise thanks | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | The first advise I would give you is to write in sentences and use proper case and punctuation. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | electric furnace? assumeing you have a ventilating airflow in/out the booth - use the furnace to heat the other room - draw the booth air intake from that area, vent outside - don't need 90 to 'set paint', just time ... if you don't have the booth vented, ignore this advice, consult yer doctor instead Bill | | | | | Joined: Dec 2006 Posts: 1 Junior Member | | Junior Member Joined: Dec 2006 Posts: 1 | Originally posted by Builder: The first advise I would give you is to write in sentences and use proper case and punctuation. Hey, Merriam-Webster, I'm betting you meant ADVICE since your usage of ADVISE in the above sentence is incorrect. Glass houses buddy... | | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | now thats funny, I dont care who you are! | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I should have put the word "advise" in parenthesis to quote the spelling in the first post.
I'm not trying to nit pick, but if you like to read stuff that looks like a kids phone text message, be my guest. I'm not trying to create a new language. You didn't spell and punctuate just for me did you Sonic?
no abla | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Ok guys, no more picking on people's grammar in this thread or it gets locked. Let's just concentrate on the question, ok?
I would not put a furnace in a paint booth. Even if you keep it shut off when you are painting it will get crusted with lots of flammable and hazardous overspray and become both a fire and a health hazard. If you want to heat the booth run duct work and shut the furnace off when painting.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2006 Posts: 39 Junior Member | | Junior Member Joined: Oct 2006 Posts: 39 | Yep. I'd put in in another room or it will come out looking like the paint color, especially the squirrel cage. For a temp. situation, you can use cardboard for duct work and through it away when you're finished. Did that many times... | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | thanks guys other room it is yep. I should have paid more attention at school!!!!!!! | | |
