Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
4 members (Hambone, Phak1, RLB, 32Fordpuchoptop), 535 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
#123403 12/07/2006 10:56 AM
ok im building a paint booth for heat i have a real nice forced air fernice it even has a air cleaner im going to run it to get the booth warm shut it down paint then crank it up to 90 to set the paint should i instal it in the booth or set it outside in the other room and run ducting if i put it in the other room it would be using cold air to heat instead of the warm air in the booth need advise thanks
#123404 12/07/2006 2:43 PM
The first advise I would give you is to write in sentences and use proper case and punctuation.
#123405 12/07/2006 2:48 PM
electric furnace? assumeing you have a ventilating airflow in/out the booth - use the furnace to heat the other room - draw the booth air intake from that area, vent outside - don't need 90 to 'set paint', just time ... if you don't have the booth vented, ignore this advice, consult yer doctor instead grin
#123406 12/07/2006 5:43 PM
Junior Member
Junior Member
Quote
Hey, Merriam-Webster, I'm betting you meant ADVICE since your usage of ADVISE in the above sentence is incorrect.
Glass houses buddy...
#123407 12/07/2006 6:00 PM
I
I Offline
now thats funny, I dont care who you are!
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#123408 12/07/2006 6:40 PM
I should have put the word "advise" in parenthesis to quote the spelling in the first post.
I'm not trying to nit pick, but if you like to read stuff that looks like a kids phone text message, be my guest. I'm not trying to create a new language. You didn't spell and punctuate just for me did you Sonic?
no abla
#123409 12/07/2006 7:52 PM
Ok guys, no more picking on people's grammar in this thread or it gets locked. Let's just concentrate on the question, ok?
I would not put a furnace in a paint booth. Even if you keep it shut off when you are painting it will get crusted with lots of flammable and hazardous overspray and become both a fire and a health hazard. If you want to heat the booth run duct work and shut the furnace off when painting.
Paint & Body Shop moderator
#123410 12/07/2006 10:12 PM
Junior Member
Junior Member
Yep. I'd put in in another room or it will come out looking like the paint color, especially the squirrel cage. For a temp. situation, you can use cardboard for duct work and through it away when you're finished. Did that many times...
#123411 12/08/2006 5:05 AM
thanks guys other room it is yep. I should have paid more attention at school!!!!!!!
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.019s Queries: 13 (0.016s) Memory: 0.6292 MB (Peak: 0.7074 MB) Data Comp: Zlib Server Time: 2025-09-22 12:05:12 UTC
Valid HTML 5 and Valid CSS
