7 members (Oswald, FAST55, Ponchogl, 2-Ton, Oldcaliforniakid, Hotrod Lincoln, Donf),
74
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | For a '51 panel, I'm missing a rear lower valance. Does anyone make one reproduction?
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I know Jim Carter sold the fiberglass reproduction , i don't know of anyone making a steel one.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tim,
Thanks for the correction - I think I am getting dotty.
After a little thought, I remembered that Metalman might have made a steel front-valance for a 47-53 New Design GMC, but no metal rear valance. That rear valance, I think, would be the same on all 47-55st GMC/Chevrolet 1/2 ton and 1 ton panel-body trucks?
Sorry - the fiberglass reproductions and fiberglass hanging-brackets are what JC sells (that style is "only game in town"). They are not bad in appearance from the top, but, they are barely able to have the valance-to-bumper rubber-seal glued to a lip in the rear. I am getting dotty - this is what I have on my Suburban (although after about 10 years of looking, I found one almost-usable used metal one). | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tim is correct. I bought the fiberglass for the rear of my panel and used my metal brackets! I got lucky on the front one and picked up a nice metal one at the Stovebolt reunion in K.C. a few years ago for $35.
Jay, it would not hurt to put an ad in the Parts Wanted section. Some guys who post parts there may not look at all the other threads/post here. Good luck. | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | PM Sent. I have a spare metal one that can be bought.
I forgot I had it and bought the fiberglass reproduction version from Jim Carter. Ok move. I got it to work but it took a lot of figuring and guesswork to get it to look decent. And then there is the whole rubber seal deal.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Can you explain the rubber seal issue? Tom | | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | Thanks!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Where does it attach to the body? Jim Carter parts made by Metalman. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The original steel rear valance has a groove or track that the rubber slips into. the rubber will be located between the rear valance and rear bumper. A lot of people suggest leaving the rubber weatherstrip off . I was told it collects moisture and dirt in the metal groove and holds it causing rust. see the groove , the rubber slips into it . rear valance groove Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not drive my Suburban much in a year. Since it gets cleaned (hose spray) when dirty/dusty, nothing gets built up below or above my rear valance rubber seal. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..yeah, we don't have to drive on the old red dirt roads like we did in the 50's and 60's ! I like my fiberglass but would take a nice metal one if it came along. | | |
