8 members (Gdads51, frogfarmer, Jon G, Hotrod Lincoln, gswbbc, Bill Hanlon, JoeDude, tclederman),
139
Mod | | | Forums66 Topics128,038 Posts1,055,536 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I have been really busy with a lot of projects and I just posted on the paint gun cleaning. I recently got the 3M PPS system which is really nice for quick clean up, and I am using it in a Devbliss Finish Line III which is a really nice gun, especially for the price. Anyhoo, I finally got the bed prepped on my 72 project and shot the paint on it, and mind you, this was a paint job done outside in the weather. We had a calm day and I went for it (despite that, the wind of course, immediately picked up!). I am very pleased with the results and this is the best I have laid paint on to date. The BPS paint is from Tractor Supply and I used Naptha to thin it and also put in their recommended hardner. After I painted a JD with it last year, I decided it was worth a go. Please note, this is about 1/3 of a gallon, which is about $10-15 worth of paint!!! Irwin\'s 72 Truck - bed painted white | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | also note the careful attention to wiring.... :rolleyes: | | | | | Joined: Oct 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Oct 2001 Posts: 428 | That looks really good. What are you going to do to the floor of the bed? I noticed that you didn't paint it white. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | How is last years JD paint job holding up. I am thinking about that paint for my panel . | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | I've posted this comment a couple of times, but the BPS Black is easy to work with too. I am using the tractor paint and so far, happy with the way it is turning out.
Nice looking white Arnswine! Great job! | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Why did I spend so much money for paint when your paint job looks so good at a fraction of the price? Live and learn. That is a really great looking paint job. | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | We'll have to see how it holds up. I had used Zero Rust with crystal coat on my 58 and that didn't last 2 years before the clear hazed up and the thing looked like it hadn't been painted. I then painted the JD last year and it still looks very good. So that got me on to this paint for this truck. Who knows if it holds up, but a top coat sure won't cost much. The bed is going to get spray in bedliner (Dupilcolor) once I get the cab finished and painted. I figured that I didn't have to worry about slopping the paint about in the bed when I spray on the booger liner. I used that same stuff in my 47 jeep on the flooring and it really made it look a lot better. I have already painted my big industrial rear step bumper in that bed liner, and I will probably paint my brush guard with it as well. The brush guard was a nice find - someone down the block (about 4-5 houses) put the thing on the side of the curb for the garbage man and I saw it and thought 'wow that ought to fit my truck'. Sure enough it seems to have been made for it! I got the truck itself from next door neighbor sans engine/tranny for $100. AC bits all had been removed as well. I didn't go perfect in the bondo on the thing mainly because with white, at 1 ft away you can't hardly see the problems anyhoo. However with the new finishline III gun and easy spraying BPS Gloss white, well, I am halfway proud of it! As soon as I get the paint did I just have to hook up my TV cable for the 700R4 and fill it with goo, plus put in the radiator, etc, and it should be ready to rock and roll. It has a 230 I6 with clifford intake/exhaust manifolds on it so it should have ok POP off the line and good economy. Will eventually replace my car. I got 96 excursion seats for it too. See my tech tip on seat cleaning. AC, coil springs, and a hydramatic, man, you could take u a woman in that!  | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Btw, the grill was ugly, so I painted it in BPS gloss black. As too be expected, it current sits in the house behind my recliner in a place of honor. Should make any booger eat texas hillbilly proud. I also hope to get those black bed plastic bed guards and tailgate liner. So white with black accents. | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | I used the BPS black on my horse trailer this summer - as a test for the '59. It has NOT rusted back through, despite the fact that I only knocked the loose rust off and it is out in the weather 100% of the time. I am really impressed with it. The '59 should be wearing its own coat by this time next year! | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Irwin, Great looking job! I painted my 4t6 in Oct haven't posted any pics cause I still am having problems with digital camera. The color seems too dark. I painted mine with BPS International white a cream color with hardener. It has a deep shine. I had 1 run and some minor dust but it polished out. My 4t6 has been in garage for at least 3 years and finally seems I'm making progress. I will always promote the tractor paints as it makes an alternative to high dollar paints. As always my opinion do what YOU want to do.
Dan | | | | | Joined: Apr 2006 Posts: 172 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 172 | anyone know if you can get the bps paint in flat black? | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | not 100% sure but john deere has flat black on em' so they could have it! tom
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | where do you get the naptha | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | The John Deere flat black is called Blitz Black. Do a search in the paint forum and on line and you will find a lot of info on it. It is what many are using for the black primer look.
I think Home Depot has naptha. | | | | | Joined: Mar 2006 Posts: 9 Junior Member | | Junior Member Joined: Mar 2006 Posts: 9 | All box stores carry naptha a.k.a. vmp naptha ( varnish & paint maker's naptha) | | | | | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | Arnswine, What type of hardener did you you with the TSC paint and where did you get it? Our TSC doesn't carry a hardener. | | | | | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | | | |
