2 members (Bill Hanlon, Otto Skorzeny), 111 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#1228168 08/03/2017 12:05 AM
Replaced the fuel pump two years ago and it leaked externally as soon as I installed it. Took it back for replacement and all went well. Until a couple of weeks ago. Appears that the fuel pump is leaking into the engine. Can anyone recommend a good pump? Airtex (Carquest) is the one I'm having issues with.
1961 Chevy C10
235 C.I. Engine
Rockauto.com has a Carter fuel pump listed for 1963 235.
I had problems wth two Airtex fuel pumps - they are now gone.
Thank you sir. Throwing the Airtex in the trash and going with the Carter.
U
U Offline
I concur with Mr. Tim's recommendation. My personal tally on the faulty Airtex 4149 pumps is three (3).
Two in one week. We never could determine "why" they would not pump, or seal.
Brad
Wrench Fetcher, PhD
Be careful- - - - -some of those "Carter" pumps are actually an Airtex pump in a Carter box!
Jerry is correct, as usual.
I did get one that was different (and, one that was the same as the Airtex).
Carburetion specialist
Find an original at a swap meet.
Call "Then & Now Automotive" in Boston, and acquire a rebuilding kit.
Rebuild the original.
Forget about fuel pump problems.
Jon.
The Carburetor Shop
Thanks, John. I think I will contact them for a spare rebuild kit.
Are the Airtex and Carter marked somehow? How to make sure the pump in a Carter box is not an Airtex?
Learned something new again! The thought of rebuilding a fuel pump would have never crossed my mind. I guess I'm too indoctrinated with the buy and replace mentality.
Larry
Installed new Carter pump this morning. A few seconds of turning over and the 235 came to life. Thanks everyone. Great site!
