4 members (Steelonsteel, klhansen, Gray_Ghost, Bill Hanlon), 54 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#1226149 07/18/2017 9:19 PM
I was given a 47 AC 524 GMC it is a really big truck, it is not in the best of shape and The cab may be the only usable part. My thought was to get a donor truck and put this cab on it. First I was thinking of getting a medium duty donor but then talked to a fellow who is using a 1 ton frame for a like conversion. Any and all thought are welcome. As of right now I do not have any specific plans on what I will do with it or use it for, just dreaming at this point. I would post pictures but photo bucket and I are not getting along. The fellow I was talking to was going to put larger wheels on his 1 ton to make it still lok like a big truck. Are there any issues using the large wheels on a 1 ton? Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
There could possibly be issues with tire clearance unless the Big Bolt fenders were used also.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
My plan was to use the entire cab fenders and grill. Dave
1941 Chevy
https://anchorage.craigslist.org/cto/d/school-bus-cat-diesel/6183716283.html
I started looking at school buses. Would like opinions good or bad about doing this swap. Above is an example of what I am looking at, shorter versions also. Dave
1941 Chevy
Have you measured the old truck yet?
How wide outside of front tire sidewalls now, and also width outside of front fenders.
How long is engine compartment from firewall to radiator? And or what engine is in it originally?
What size tires on it now and best guess at how tall might still fit fine?
The buss pictured likely has a CAT C7 which is inline 6 and from all I hear not very desirable, expensive and troublesome, or can be later. Or it may have a 3208 which is a V8, slightly better reputation but not by a lot, probably to wide to fit in engine compartment.
Start with measuring the truck and your best guess at what modern engine, front axle width, and wheels might fit, then hunt for chassis with those.
1952 Chevrolet 3800 pickup
---All pictures---
I was looking at school busses for my latest project and after looking at them decided not to go with one because they are designed to go about 65 mph max speed. They do not have a rear geared for they highway. I bought a 99 international 8100 for a donor. It cruised 80 mph on the way home and has a 9 speed, a/c ,cruise, air ride, and air brake. All the things you will not find in a school bus.
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
Good thoughts, thanks! Dave
1941 Chevy
Newer school busses around here do have air ride and air brakes, and modern electronic Allison automatics, with overdrive.
Rear gear ratios are available and pretty cheap and easy to exchange if necessary. At least for medium duty trucks and busses for the last 30 or more years. Older stuff like our antique trucks may not have better gear ratio choices, but newer stuff does for sure.
---All pictures---
There is a group on facebook called "Killer One Tons and COEs" that has a huge member base and is very active. Most of the folks on there are into this sort of thing. I'd suggest joining that group and posting your query there. You'll get a ton of response, quick.
1950 4100 - unrestored and driven weekly for almost no reason at all.
Crusing in the Passing Lane
You might have to enhance your license with air brakes, which many of these trucks have.
Ed
Moderator
Moderator
2 Offline
Ed
It may be different in other states, but in Missouri, if you put historic plates on it, you do not have to have a CDL for air brakes.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
