8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,140 Posts1,056,770 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 794 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 794 | Does anyone have a good source for the steel brake line and wiring clamps used on AD trucks? These are the clamps that secure brake lines and wiring to the frame rails or cross members. Some of mine are missing, others are rusted and/or broke. I haven't found much locally other than cheap plastic replacements. Maybe someone has a stash of these clamps and would part with them?
Thanks, | | | | | Joined: Dec 2013 Posts: 794 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 794 | Thanks Tim! I was hoping to find some 'original' style clamps, but at least there are some options.......... Classic PartsChevys of the 40s | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Andy, Post links to pictures of what you are looking for. Also, Restoration Specialties & Supply, Inc. has an icredible collection of small parts. The only "problem" is finding them in their catalog. They also have a GM section in the catalog. http://www.restorationspecialties.com | | | | | Joined: May 2015 Posts: 11,125 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,125 | Jim Carter's PN EL175 looks original, but I could be wrong.
Maybe if you post a link to a picture of what you're looking for, someone could help.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2013 Posts: 794 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 794 | Good ideas and options. Here's what I have and it came from an inner fender well. Wire Clip 1 Wire Clip 2They appear to be used fro 1/4" brake lines too. I guess I didn't see the JC clips and I even called them to see if they carried them! Wiring Harness Clip EL175Thanks guys, | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Jim Carter pretty close but Out Of Stock! Same part as Classic Parts 52-905 .
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If they are not being seen I like to use the "coated rubber" clamps/straps on the steel brake and gas lines..... but that's just me. | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Andy, Inline Tube . com has an excellent selection . https://www.inlinetube.com/George '54 3600 | | | | | Joined: Dec 2013 Posts: 794 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 794 | Thanks George, These clips and clamps are even available for the correct model and year. 1947-1950 Chevrolet Truck | | |
